Old 12-12-2002, 01:22   #1 (permalink)
Member: 17842
3310 after re-heat sim not accepted?
HI! I got a 3310 with signal problem .. i re-heated the whole pcb .. it has philips PA in it, i heated that from the other side of the pcb .. at the end i tried the phone, and now i get simcard not accepted, the phone was unlocked!!! i tried to unlock it but it's the same, what to do? what went wrong? thanks!!
Old 12-12-2002, 02:17   #2 (permalink)
Member: 633
Thanks Meter: 37
Try rehot cobba or exchange it.
-Zoio-
Old 12-12-2002, 06:14   #3 (permalink)
Member: 1060
Thanks Meter: 10
Re: 3310 after re-heat sim not accepted?
Gsmdeli,
"rehot" will not help to repair your phone ,, you just try to kill the phone !
if Vcobba and Vbb is ok, then you need to reball COBBA !
OR MAD !
Willy
Old 12-12-2002, 10:32   #4 (permalink)
Member: 17842
Hi! What exactly "reball" means? Replace it? I tried to rehot ,because the phone fell of the table!!
Old 12-13-2002, 10:22   #5 (permalink)
Member: 15200
Thanks Meter: 3
maybe u mush check cpu too
Old 12-13-2002, 11:37   #6 (permalink)
Member: 7767
Thanks Meter: 3
Reball means, that You must desold Cobba from pcb and create new balls on Cobba by using BGA repair kit, for example. After that, sold it again.
Old 12-13-2002, 18:50   #7 (permalink)
Member: 8041
@ gsmdeli
check with unlock program if locks been closed as i had few where by reflowing the locks would close........ just try unlock then..... or if more serious u could hav certain type contact service but good to check with wintesla for type of failure?? normally if contact service, software upgrade helps but not always!
hope u sort it out........
Old 02-29-2008, 12:03   #8 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
this fault is software related download any nokia tool . purchase a serial cable then unlock the phone.
Old 02-29-2008, 12:19   #9 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Replace the cobba IC and rebuild the IMEI.
Old 02-29-2008, 12:32   #10 (permalink)
Member: 654329
Thanks Meter: 7
yup thats right the only way is to replace the vcobba or audio ic.....
Old 02-29-2008, 12:53   #11 (permalink)
Member: 530721
Thanks Meter: 157
before reball or rehot if u have eeprome tool try it once good luck
Old 02-29-2008, 16:10   #12 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Check ur COBBA. . . .
n620 samsung one sim accipet other compnay sim not accept shani72 VLSI, Conexant, Skyworks and Old Models 5 11-22-2009 13:34
After flashing 3250,sim not accepted shirly Nokia Base Band 5 ( BB-5 ) 2 02-18-2007 21:01
E700-32K Sim OK, 64K SIM Not Accepted Qantas Trident/AGERE Platform 0 04-28-2005 13:26
Nokia 3310 v4.18e S1(D2) -Simcard not accepted! Ved Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-05-2001 07:41
change led 3310 = 4 locks closed.. card not accepted trafix Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 08-23-2001 22:37
Page generated in 0.21809 seconds with 9 queries
