Old 12-16-2002, 10:17   #1 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
3310 - batt empty after 1 min of talking...
this one is a little bit crazy....so:
i changed 3 PA`s...
the antenna switch too ...
with another battery same thing... power off after ~1min.
what else can i do ?
10x!
Old 12-16-2002, 17:53   #2 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,164
Flash the phone whit a full flash and after try.
Old 12-16-2002, 18:18   #3 (permalink)
Member: 1060
Thanks Meter: 9
TRY to replace CCONT
and check connect between battery to PCB !
Willy
Old 12-17-2002, 09:16   #4 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
I flashed the phone 200-400 and i changed the connector too ...still
Old 12-17-2002, 09:41   #5 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
now i changed the CCONT and the same thing (
i HATE this phone !!!!!!!!!!
Old 12-17-2002, 10:31   #6 (permalink)
Member: 3381
Thanks Meter: 1,164
Probably Mad on your phone is bad.
Old 12-17-2002, 10:46   #7 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
let me tell you what happend to this phone before it came to me:
this guy lost his phone and some lady found it ....he called the phone nr and she gave it back ...with the LCD broken
when i opened the phone the PA was broken too(i don`t know how he managed to call her???) i changed both the LCD and the PA
i must say that the PA type had plastic cover and i put 08109(metal type)PA
could this have anything to do with it ?
lie to me and tell me it`s not MAD problem after i told you this
Old 12-17-2002, 19:32   #8 (permalink)
Member: 3858
Thanks Meter: 2
You forgot very important thing to clean all baterry contacts
Old 12-18-2002, 02:21   #9 (permalink)
Member: 11937
Hey
If you change between the Hitachi & Phillips PA's you need to insert / remove/ change a resistor! I cant remember off-hand which one it is, but look in previous posts
Old 12-18-2002, 12:57   #10 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
i managed to find plastic PA, and still discharges the battery.......
the battery contacts are so clean that i can see myself in them...
Old 12-18-2002, 17:18   #11 (permalink)
Member: 16982
is it after 1 minutes the bat is and shut down, and after that it can turn on again? , it happen to me after changing PA i think is PA problem because i found 2 phone 1 is already demage because I try to remove lamost every thing, the second I change again with the black one now is ok, so better find another PA
Old 12-18-2002, 17:29   #12 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
yes i can turn on(does NOT restart) the phone after it says batt empty and it shows 4 batt lines ....but as i said i changed 3 metal PA`s and 1 plastic , and still discharges the batt after ~30-40 sec`s of talking
in standby mode lasts up to 3 days
Old 12-19-2002, 01:37   #13 (permalink)
Member: 11937
You can rule out the PA by running netmonitor & checking the phone power consumption test while making a call. I have a benchtop power supply with a built in ammeter which i use to check the phones power consumption too.
I had this problem once , and i did everything!! changed, PA, CCONT, COBBA, HAGAR, CHAPS, everything!!! still did not work. I suspect crack in PCB or CPU problem.
Old 12-19-2002, 10:56   #14 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
could you tell me how can i read the power consumption on net monitor ?
i really don`t know wich one shows the PA or what else shows there...
The Following User Says Thank You to jokkergsm For This Useful Post:
Old 12-20-2002, 01:25   #15 (permalink)
Member: 11937
OK, activate netmonitor using Logomanager or similar program. Go to test number 23. In the bottom right hand corner there is a number, the one above it is the phones power consumption. Normally on a 3310 with lights off, not making a call it is around 9. Lights on around 140, making a call, it will vary. By looking at this when you make a call, you can rule out excessive power consumption by the PA
6230 "not charging" after 15 mins of charging .. ?? TRABEL Nokia Hardware & Hardware Repair 5 05-23-2006 11:52
6100 turn off after 1 min emso Nokia Hardware & Hardware Repair 6 07-06-2005 02:00
5210 lost signal after 1 min of talking mobils Nokia Hardware & Hardware Repair 7 04-16-2003 08:29
C45-after 1 min-"Wrong Software" solution angele x1x to x45/x50 0 11-29-2002 23:09
3310 dead after 1 min. to 2 hr. gsnbhagawan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-06-2001 12:02
Page generated in 0.35889 seconds with 8 queries
