12-20-2002, 10:12 | #16 (permalink) |
No Life Poster Join Date: Jan 2002 Location: freak land Age: 44
Member: 8866 Status: Offline Thanks Meter: 50 | on stdby-9\ lights on-160~\calling(lights on)-400~\calling(lights off)-250~.... i guess it`s ok... u know ... i think i`m gonna throw it away ..... .... after all, i tried too much on a single phone....... |
12-21-2002, 09:57 | #19 (permalink) |
Guest
Posts: n/a
Member: | Yesterday. And, that phone was in many repair shops, but none of them didn't repair that phone. So, it's logical, those caps are power reservoirs, like on remote control units - if you have bad electrolitic cap in it, it will discharge battery very fast. So, it is good idea. This "Elco" thing is useful when you got "!" on Siemens phones, also if you have no network at all. I've replaced many of them in CMS35 phones, and in Nokia 33XX . . . |
12-21-2002, 20:51 | #20 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 43
Member: 6772 Status: Offline Thanks Meter: 17 | Realy???? Do you think that power reservoir 3.3 Mf is enough for PA ??? I don't think so...... May be your PA's soldering was bad. PS: PA is the most power consuming element in the phone. |
12-21-2002, 23:46 | #21 (permalink) | |
Guest
Posts: n/a
Member: | Sure, you don't need those caps, just remove them and you will see . . . Quote:
12-22-2002, 06:47 | #22 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | b0ba. Thats right, but when you run the netmonitor power consumption test and its within limits and it still cuts out, your left scratching your head.... legija. your saying to remove those caps completely?? hmmm, i dont see the logic in that, if they wern't needed, why would nokia put them in the first place?? Or are you just been sarcastic??? |
06-17-2003, 11:00 | #24 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | @Legija, Show us on PCB Hello Mr Legija, Pls use this PCB to pin point the 2 yellow chip U talk about. Link: http://nokiafree.org/forums/showthre...threadid=29369 Thanks dannyogolo |
06-17-2003, 12:26 | #25 (permalink) |
Member: 8866 Status: Offline Thanks Meter: 50 | give it up guys ...i solved that phone a long time ago ... it was ccont fault...(i got mad so i started to change all bga`s ) anyway legija ...those two capacitors that you are talking about, are nothing but an innsurance , they are not truly important ... the phone can work very well with or without them... indeed nokia wouldn`t put them just because they fit there the only problem would be when they were shortcutted |
06-18-2003, 10:41 | #28 (permalink) |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | @Legija, Are you saying you will not show us the 2 yellow "things" to remove? If so too bad. I hope you will. How about 8210 that trips off when trying to log to network, but without sim, no tripping off? Try to help. dannyogolo |
06-18-2003, 12:32 | #30 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | legija is right !!!! Learn more about decoupling capacitors !!!! If You get more into that subject, use some formulas to calculate power consumption of PA, current changes of PA in period of time, etc. You will find that there exists no battery able to supply power to PA which emits signal !!!!!! Therefore, we have decoupling capacitors. In simple words, they accumulate power and give it out when is necessary. Remove them and You will get phone which turns off, block, resetting.... BR Vule |
6230 "not charging" after 15 mins of charging .. ?? | TRABEL | Nokia Hardware & Hardware Repair | 5 | 05-23-2006 10:52 |
6100 turn off after 1 min | emso | Nokia Hardware & Hardware Repair | 6 | 07-06-2005 01:00 |
5210 lost signal after 1 min of talking | mobils | Nokia Hardware & Hardware Repair | 7 | 04-16-2003 07:29 |
C45-after 1 min-"Wrong Software" solution | angele | x1x to x45/x50 | 0 | 11-29-2002 23:09 |
3310 dead after 1 min. to 2 hr. | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-06-2001 12:02 |
