10-28-2002, 07:19 | #1 (permalink) |
Junior Member Join Date: Sep 2002 Location: Malaysia Age: 42
Member: 15979 Status: Offline Thanks Meter: 0 | 3310 battery can't stand longer i have already change two original bat, travel charger and charging connector aslo same problem. Can anyone Master here tell me how to solve this problem???....So confuse!...Thank You... |
10-28-2002, 07:25 | #2 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | This master can! heheh. First of all you need to check how much power the phone is pulling. Easy but inacurate way 1) Activate Netmonitor & go to Menu 23. In the bottom right hand corner there should be a readout which indicates power used by the phone. Watch which one changes when the lights go on / off. This should be aroun 3 - 9 when the phone is just sitting there with the lights off. If its any more than you have a short or fault drawing power from the VB line Hard but good way - you need a benchtop power supply with ammeter built in 2) I hook up all my phones to my bench power supply, and the built in ammeter tells me what amount of power the phone is pulling. This is the best way Or it could be bad calibration - try flashing a new MCU / PPM / eeprom & do a total reset in Wintesla. Hope this helps Regards Filip |
10-28-2002, 07:26 | #3 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
change pa-- broken pa/unsodered normally cause this problem-- best of luck-- best regards gohar | |
10-28-2002, 07:35 | #4 (permalink) |
Member: 11937 Status: Offline Thanks Meter: 1 | Yes, it could be the PA. However don't go blindly resoldering / changing componets hoping to find the right one. In my experience it always leads to grief with a dead phone!!!! |
MiLi Power Angel External Battery with Stand for iPhone & iPod(Red/1200mAh) | IPMART | ipmart WebShop | 0 | 01-14-2010 15:50 |
MiLi Power Angel External Battery with Stand for iPhone & iPod(Blue/1200mAh) | IPMART | ipmart WebShop | 0 | 01-14-2010 15:50 |
MiLi Power Angel External Battery with Stand for iPhone & iPod(Black/1200mAh) | IPMART | ipmart WebShop | 0 | 01-14-2010 15:50 |
Help!!... Can't no longer use GsmFather | katalyst | Gsmfather The Wholesale Unlocking Database | 18 | 09-20-2008 17:41 |
Is there a schematic for Battery Charging Stand DDC-1? | Yolly Zubrick | Nokia Multimedia | 0 | 07-12-2003 21:55 |
