10-07-2002, 01:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | 3310 black display? Yesterday I met Nokia 3310 when it power on it shows blank black display then nothing more. I tried to flash still same. Also it doesn't connect to m-bus connection to pc. Who know this pb? |
10-07-2002, 16:25 | #6 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Mujie , Hmmmm, at 3310 : V100, which is connect to XMIC and to work for "HOOKDET" and it is use for AUDIO COBBA ! Change V100 can help ? Willy Quote:
10-07-2002, 16:36 | #7 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | There is some link make LCD do not display or Mbus problem eg: 3310 1: MAD 2: VBB from CCONT Mbus has a Pull HIGH resistor R307 , pull high from VBB ! also VBB for N400 , and LCD need VBB too ...... run wintesla for self test before you remove MAD ! if wintesla can not fine phone , then check at R307 , R200 for VBB if phone can not into normal mode, it must be VBB problem , replace CCONT first . Willy |
10-12-2002, 11:43 | #14 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Bogatic , RS Age: 56
Member: 4395 Status: Offline Thanks Meter: 159 | willy i have big prob m-bus communication not work, flashing is ok i change cobba and ccont even reballing MAD only hagar i dont touch and allways black screen any idea? thx |
10-12-2002, 12:44 | #15 (permalink) |
Member: 11208 Status: Offline Thanks Meter: 11 | To brka1 Hi. Make jumper near from cpu to display contacts. I can't say exactly from which point to ... Becuase it is too difficult for describe. You can find them working pcb with good multimeter. Wish you good luck. Bye Last edited by gsmsalers; 10-12-2002 at 13:34. |
No display-3310 / white display-6600 / blue screen-6085 | Jayasinghe | Nokia Hardware & Hardware Repair | 0 | 09-08-2008 03:25 |
3310 black screen | kojote | Nokia Hardware & Hardware Repair | 5 | 11-25-2003 13:32 |
3310 black display | ::.::HITGSM::.:: | Nokia Hardware & Hardware Repair | 6 | 03-01-2003 12:59 |
3310 black LCD | Erik | Nokia Hardware & Hardware Repair | 1 | 02-09-2002 04:47 |
3310 black screen after removing L511 | eureka8888 | Nokia Hardware & Hardware Repair | 4 | 01-17-2002 11:58 |
