06-15-2002, 09:04 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | For everybody!!! If you can flash your phone but it doesn't turn on your flash IC is defective!!! Everyday people ask this question. Search previous threads. |
06-16-2002, 21:31 | #3 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | Quote:
How do you replace Flash IC?? Isn't it there is some sort of clear covering on all 4 sides of the Flash IC, If you try to hot air someone says you might damage the Flash IC?? Any technique you get in replacing them?? Pls post here. Thanks....kabayan BR, Epic | |
06-24-2002, 07:25 | #8 (permalink) |
Insane Poster Join Date: Nov 2001 Location: Kingdom of Saudia Arabia
Member: 7155 Status: Offline Thanks Meter: 0 | Try to Fexed again , there is no solution , so many teqnitians cant change this kind of flash ics , this depend on your experiance . WBR Osama Alkhoraish |
07-01-2002, 12:35 | #9 (permalink) |
Freak Poster Join Date: Aug 1999 Location: Brisbane, Australia
Member: 406 Status: Offline Thanks Meter: 2 | i know this sounds obvious but is your battery fully charged???? lots of my friends have had problems trying to fix ocntact service by flashing with nearly flat batteries... result no power up it looks like it flashes ok but won't switch on tried same phone with fully charged battery worked perfect might work... might not.. worth a try though |
SE T100 dead but can flash in Div | robba | Sony Ericsson Hardware Repair | 2 | 04-07-2004 07:46 |
t100 dead.. but can flash | s4sajii | Samsung Hardware Repair | 6 | 02-14-2004 03:44 |
s35 dead but can flash | joe locks | x1x to x45/x50 | 7 | 09-21-2002 20:05 |
