02-07-2006, 20:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | 3310 cant power on with battery |
02-08-2006, 20:46 | #8 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | battery terminal and power on/off switch already change with working one. but no result now trying to find broken print.... is it really a broken print problem or any other reason for that?... |
02-10-2006, 07:31 | #9 (permalink) |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | insert charger and check if the unit could charge (batt indcator).. the problem would be in the power switch to diode line (if you have schematic, you cn trace it easily) |
04-06-2006, 21:51 | #10 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | power swtich to diode print is ok test by multimeter... which print way is broken any diagram for that ....waiting |
04-06-2006, 22:20 | #11 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Phone Power On With Ufsx Box But Not With Battry Quote:
1st-check from r224 ,v414 ,r402 to on/off switch 2nd-check the curcuit from cpuF2 to KeyUp ,KeyDown ,Key3 ,r414 ,v415 3rd-ccont A4,D2,F1,G1,G3,G5,H6 to c228 curcuit damage 4th-from batter supply BSI to r221,r220 5th-r221 to ccont C6 6th-r220 to ccont B3 check every thing,fault must be here this is tested solution....colected from this forum | |
04-07-2006, 19:27 | #13 (permalink) | |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
09-02-2006, 09:37 | #15 (permalink) | |
Banned Join Date: Aug 2006 Location: Iligan City,philippines
Member: 332569 Status: Offline Thanks Meter: 8 | Quote:
Does the unit will charge? if not try to use power adapter 7.5v connect it to to your mobile and power on then remove the adapter and use the battery and power on the phone. | |
n70 cant power on with battery | ><the mad>< | Nokia Hardware & Hardware Repair | 3 | 11-07-2009 21:58 |
3310 cant power on | inti_cell | Nokia Hardware & Hardware Repair | 11 | 02-26-2008 09:02 |
Urgent please help on nokia 2310 software ok but no power on with battery | mobilecitycbk | Nokia Hardware & Hardware Repair | 1 | 11-15-2007 13:09 |
3310 Phone Power On With Ufsx Box But Not With Battry | hafeez48 | Nokia Hardware & Hardware Repair | 20 | 09-21-2006 22:21 |
3310 cant power on after switching off | ViperGSM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-14-2004 19:34 |
