11-18-2002, 17:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Serbia
Member: 9165 Status: Offline Thanks Meter: 0 | 3310 charge problem display "Battery dont charge" ? I check charger it's OK, then put another battery in that phone, and charge go OK, when i put "old" battery (6 month) then phone charge that battery? Gremlins? |
11-18-2002, 21:52 | #2 (permalink) |
Junior Member Join Date: Oct 2002
Member: 16495 Status: Offline Thanks Meter: 0 | hii are you trying to charge a new battery? have you tried to charge the battery with another phone? sometime new battery don't have enough voltage. measure the battery with multitester, if below 3 volts it wont get charge. you can zap it with small DC adaptor with 4,5 or 6 volts - 500mA for a minute or less or until the volt rises to normal between 3 - 3,6 volts |
11-18-2002, 22:24 | #4 (permalink) | |
Member: 9165 Status: Offline Thanks Meter: 0 | Quote:
phone 6 month. And when time for charge is come, put plug in phone, and that i receive on display. I try what you say to "flash" battery with higher voltage and that will work for now. Phone start to charge that battery. But, before that, i put that battery in another phone and another phone charge that battery, when i put that battery in origin phone, the origin phone is start to charging battery which is not charging before few minutes. | |
3310 charging problems | Hanukkah | Nokia Hardware & Hardware Repair | 3 | 05-18-2005 15:06 |
3310 Charging problem | Vicky | Nokia Hardware & Hardware Repair | 5 | 10-14-2004 18:59 |
3310 charging problem | SubTen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-18-2001 09:37 |
3310 charging problem | garcea10ro | Nokia Hardware & Hardware Repair | 2 | 10-24-2001 16:07 |
3310 charging problem | pornopig | Nokia Hardware & Hardware Repair | 5 | 10-08-2001 20:37 |
