02-23-2004, 16:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Romania Age: 41
Member: 17740 Status: Offline Thanks Meter: 1 | 3310 charging when it is on it displays after few seconds not charging!!! please help |
02-25-2004, 13:40 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @c0c0 Do a search in search window like this "3310 AND charging" this subject have been covered in countless posts over the last 3 years on this board. You will find only like 150 different threads with this problem...... Regards |
02-25-2004, 14:58 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | measure voltage with charger connected on + and - pole of battery contacts ... if its 4,5V-6,8V .... then u have a broken PCB ... use attached picture to fix your problem. b.r. ALexandar. |
02-25-2004, 16:59 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | @brka .. I'm afraide that the atached pic has a littel mistake ,the voltage devider R200,R208 ( 120Ohm,3k3 ) gives voltage refrence = 3.47 volts in case of volt IN = 3.6 V. In the pic the connection is directelly fromm V+ to the ref. point ommiting R200 !!!, and also raiseing the charging ref. Volt to +ve level directly. |
02-25-2004, 17:07 | #7 (permalink) | |
Member: 17740 Status: Offline Thanks Meter: 1 | Quote:
cheff i have tried searching for old posts but all i find it was this picture wich is not my case .... my phone doesn't say reconect charger, my phone when it is turned off and without charger only battery sign appears and then after few seconds it dissapers! when i plug the charger nothing happens ..... when i turn the phone on it says nothing only a beep from few seconds to few seconds! | |
nokia 3310 charges but not storing charge | nellabe | Nokia Hardware & Hardware Repair | 3 | 05-24-2010 19:20 |
3310 charging problems | Hanukkah | Nokia Hardware & Hardware Repair | 3 | 05-18-2005 15:06 |
3310 Charging problem | Vicky | Nokia Hardware & Hardware Repair | 5 | 10-14-2004 18:59 |
3310 charging problem | SubTen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-18-2001 09:37 |
3310 charge | Rossend | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-01-2001 17:39 |
