Old 12-01-2003, 12:01   #1 (permalink)
bossko's Avatar
Member: 17761
Thanks Meter: 91
3310 charging problem
When my 3310 is power on and charging, is shut down if phone is fully charged.
I tryed change N200 4370621, no success. Any IDEA?
Many Thanks.
Old 12-02-2003, 05:43   #2 (permalink)
Member: 44386
hi, try to change ccony ic ,is possible happen with cpu good luck
Old 12-02-2003, 15:41   #3 (permalink)
celtec's Avatar
Member: 25504
Have U tried to make a Default Data of trimming ?
Old 12-02-2003, 23:09   #4 (permalink)
Member: 44658
have you any equipent, see how currnet your phone is drawing, may need a PA
Old 12-03-2003, 14:02   #5 (permalink)
bossko's Avatar
Member: 17761
Thanks Meter: 91
Change CCONT, try without PA, no succes.
Phone was restart without ask for PIN, or turn off. Another battery same problem. Without charger all OK.
Any idea?
To celltec: How can I make default data of trimming?
Old 12-04-2003, 09:36   #6 (permalink)
celtec's Avatar
Member: 25504
U can make Def/data by Wintesla.
If U haven't SW U can use for exsample KNok, by phone settings menu and then Reset DEV,settings.
Alex
Old 12-11-2003, 05:59   #7 (permalink)
Cheater -Don't Deal with him-
abbeydguru's Avatar
Member: 23994
Thanks Meter: 43
try to change the PA
Old 12-11-2003, 20:13   #8 (permalink)
bossko's Avatar
Member: 17761
Thanks Meter: 91
I will try without PA. Same problem.
3310 charging problems Hanukkah Nokia Hardware & Hardware Repair 3 05-18-2005 15:06
3310 Charging problem Vicky Nokia Hardware & Hardware Repair 5 10-14-2004 18:59
3310 charging problem SubTen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-18-2001 09:37
3310 charging problem garcea10ro Nokia Hardware & Hardware Repair 2 10-24-2001 16:07
3310 charging problem pornopig Nokia Hardware & Hardware Repair 5 10-08-2001 20:37
Page generated in 0.23473 seconds with 10 queries
