Old 03-26-2006, 13:06   #1 (permalink)
venuskarthick's Avatar
Member: 233140
Thanks Meter: 617
Post 3310 Condact Service
3310 Mcu Ppm Flashing & Ui Setthings R Ok But Set Stell Condact Service
Old 03-26-2006, 13:08   #2 (permalink)
artusius's Avatar
Member: 82796
Thanks Meter: 21
Reball or reheat COBBA and FLASH IC
Old 03-26-2006, 13:19   #3 (permalink)
Member: 233140
Thanks Meter: 617
Friend
I Applied Heat On Ic Still Same
Old 03-26-2006, 13:31   #4 (permalink)
faisi's Avatar
Member: 143322
Thanks Meter: 35
read flash file of good 3310 with dejaan box and after this write flash to the fone......ur pb. solved..test by me on many sets.....
BR.
Faisal.
GSM Mobile Lab.
Old 03-26-2006, 13:33   #5 (permalink)
Member: 233140
Thanks Meter: 617
I Have No Dejaan Box
I Have Only Ufs
Old 03-26-2006, 14:02   #6 (permalink)
bingo_888's Avatar
Member: 234955
Thanks Meter: 19
Friend
hi,
change cobba...
Old 03-26-2006, 14:31   #7 (permalink)
artusius's Avatar
Member: 82796
Thanks Meter: 21
Hi all,
Contact service problem solves with flash when phone swith on and it write "insert sim" and after few seconds restart in contac service.If "contact service" appear afterr switch on,without "insert sim" this fault is 100 % hardware.
What I do:
1. Connect to UFS and press "check".If first boot O.K next step
2.Reheat(better reball COBBA,FLASH IC,RAM) if problem still do next
3.Change COBBA or FLASH IC and reflash phone with UI settings,repair IMEI
After this operations you will give alived phone.
Good luck
Old 03-26-2006, 14:35   #8 (permalink)
Member: 233140
Thanks Meter: 617
Thank U............................
Old 03-26-2006, 18:42   #9 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,404
1st flash the phone
2nd rebuild imei
3rd ui setting
if not ok then change cobba ic
[email protected]
Old 03-26-2006, 21:30   #10 (permalink)
b0ba's Avatar
Member: 6772
Thanks Meter: 17
Where is Zloy?????????????
Old 03-27-2006, 08:59   #11 (permalink)
Member: 243896
Thanks Meter: 10
you check flash ic and poweric
Old 03-27-2006, 10:43   #12 (permalink)
artusius's Avatar
Member: 82796
Thanks Meter: 21
Zloy is in ************.ru
Old 03-27-2006, 10:45   #13 (permalink)
artusius's Avatar
Member: 82796
Thanks Meter: 21
Zloy is in mobilefiles.ru
Old 03-27-2006, 11:19   #14 (permalink)
Member: 108629
Thanks Meter: 16
This solution is discussed many time so make search and u will find perfect solution
Old 03-27-2006, 11:58   #15 (permalink)
G i l l a n i's Avatar
Member: 248178
Sonork: 100.1579207
Thanks Meter: 322
plz take it in PMM and flash with this file not mcu+PPm. then rebulit imie ur phone will ok
Gillani
0304-6001000[IMG]http://www.*******.com/forums/images/smilies/New%20Smilies/girang.gif[/IMG]
The Following User Says Thank You to G i l l a n i For This Useful Post:
5130 condact service solved on hwk shakkeermp HWK 7 10-18-2009 14:23
9210i condact service ummercheriyil Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-13-2008 17:54
Page generated in 0.38359 seconds with 9 queries
