3310 dead 3310 No power on even not charging battery cannector point +B to gnd short whats a problem? thanks shri |
does power button, click on/off? have you tried flashing the phone? |
Hi! Simple check...with a DCpower supply with current indication apply 3.8V to +and - of the phone...if consumption is 30mA or high U need to flash .. If its less...U have hardware problem... Good luck! Big8 |
on/off switch ok CCONT & PF remove but still showing short circuit + - short i want 3310 circuit diagram where i download or show circuit daagram thanks shri |
if + - are shorted : may be some capacitors are shorted.there is more than 18 capacitors in this lines! If you removed chaps,ccont and pf and still short,you need to check many little parts. just serch for 3310 service manual on forum.but some times MAD cause this fault. |
i want 3310 circuit diagram where i download or show circuit diagram thanks |
Hi man, There is one attachement in PDF format. Download it and open it by adobe reader. Best of luck. Jem |
remove P.A first. |
check backlight, ringer, vib. I.C, check leds for shorts. |
mansi wrote: check backlight, ringer, vib. I.C, check leds for shorts. I cant understand relation between buzzer,vibra and led short with VBAt to ground short! Dont waste ur time with this because: Led's to groun have R486 and R437 . Vibra has link to N400 Pin 16 and VB Buzzer VB and N400 pin 6 Just remove N400(UI driver) CCONT , Chaps,PA,C575,C274,C228,C202,C235 and some other capacitor on VBAT-GND line |
remove all ics and see the shorting mainly pf ccont chaps, hager ic if not solve there may be internal sorting swap phone |
I cant understand relation between buzzer,vibra and led short with VBAt to ground short! Dont waste ur time with this because: Led's to groun have R486 and R437 . Vibra has link to N400 Pin 16 and VB Buzzer VB and N400 pin 6 Buzzer PADS can be shorted to ground, also VIB PADS, LEDS could have direct connection to ground befor track reaches the I.C . trying to help, beside i had these problems befor. thanks you |
This parts are not in VB lines.If you see any short to ground in Vibra or buzzer N400 has shorted,If you move N400 you will see short gone! |
thanks for all i replace the CCONT ic But after replace CCONT ic on the power switch CCONT ic heat thanks shri |
hi shri, there is some mistake in replace ccont. reball and relace it again or replace with new one ccont. then check output of ccont. vbb-vcore- vxo.. w.b.r. |
