06-14-2002, 14:13 | #2 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Hello For normal flash data corrupt the 3310 power on current will be 20MA if after you reflash it and check the current still is 20MA you can try to change your flash chip. there are some pins broken. good luck other wise you should check the ccont. |
06-25-2002, 20:37 | #4 (permalink) |
Junior Member Join Date: Jun 2002 Location: Malaysia Age: 55
Member: 13245 Status: Offline Thanks Meter: 1 | try to use power supply to see if you phone can power On or not if its power ON using power supply then just change the ON/OFF switch if its doesnt power ON using power supply then is other problem or u have flash a wrong data file ICQ: 1597957 |
3310 dead or not dead | amralkareem | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-28-2006 17:34 |
3310 dead can flash ok but dead | mobilemafia | Nokia Hardware & Hardware Repair | 12 | 06-02-2004 00:06 |
3310 dead after wrong flash, after buckup it not turn on????? | Oleg_ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-18-2002 12:35 |
3310 DEAD plz help | Ziba | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-08-2001 10:04 |
3310 dead after 1 min. to 2 hr. | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-06-2001 12:02 |
