09-30-2003, 14:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: mumbai Age: 54
Member: 7889 Status: Offline Thanks Meter: 7 | 3310 dead can flash ok but dead while it can powered on on jig so its bsi problem after shorting bsi to ground phone works g*** but dont charge anymore changed ccount already |
10-05-2003, 03:08 | #6 (permalink) | |
Freak Poster Join Date: Nov 2002 Location: MX-KEY is the BEST NOKIA TOOL Age: 49
Member: 17367 Status: Offline Thanks Meter: 16 | Re: 3310 dead can flash ok but dead Quote:
10-07-2003, 02:19 | #8 (permalink) | |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
any way follow the vbb line not the bsi .. and i think you must check the ccount ic may b you use some from hatem or attaba ic's | |
02-09-2004, 15:41 | #9 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: hell
Member: 39245 Status: Offline Thanks Meter: 43 | Quote:
Any solution for this problem?? CCONT have changed.... I don't think so if it was Flash IC. | |
06-02-2004, 00:06 | #13 (permalink) |
Junior Member Join Date: Jun 2004
Member: 67473 Status: Offline Thanks Meter: 0 | @MobileMafia 1)BSI goes to 2x10k Resistor Network located top right of ccont almost against the frame. 2)From opposite side of 10k resistor network it links to pin B3 of ccont. U have broken track on either of these points. BRIDGE IT! |
6020 flashing ok but dead | c_ahmad79 | Nokia Hardware & Hardware Repair | 6 | 08-02-2006 02:23 |
3200 (RH-30) Flash Ok but Dead | goga3000 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 04-25-2006 19:35 |
Dead S35... Flashed OK.. but Suddenly off | CellM@n | Siemens Hardware Repair Area | 5 | 04-15-2002 23:36 |
