09-10-2004, 17:55 | #10 (permalink) |
No Life Poster Join Date: Mar 2004 Age: 46
Member: 57930 Status: Offline Thanks Meter: 24 | hi man in 1st use avo to check voltage on switch if volt > 3.2 yr phone is software or u must change flash chep if volt < 3.2 chenge CCONT or clean it 1st and put it again GOOD LUCK if u wanna support [email protected] |
09-14-2004, 11:23 | #11 (permalink) | |
Crazy Poster Join Date: Aug 2004 Age: 59
Member: 79745 Status: Offline Thanks Meter: 27 | Quote:
09-14-2004, 20:34 | #12 (permalink) |
Insane Poster Join Date: Aug 2004 Age: 43
Member: 79647 Status: Offline Thanks Meter: 1 | hi first chechek on off switch prints may be break {track } and after that check on soft ware if response is same than check first all prints of pc b if result willl same than cahnge cocont crystal {26mghz} than work step by step work on pcb its not difficult so when ever u succeeced tell about it. if not than inform me too good luck |
gx25 don't power on and don't charge | duvud67 | Sharp | 0 | 04-15-2006 09:15 |
3310 leds but don't power on | [Rod] | Nokia Hardware & Hardware Repair | 5 | 02-16-2004 23:05 |
n3330, don't power on, power switch ok | pali | Nokia Hardware & Hardware Repair | 6 | 07-28-2002 08:48 |
Nokia 3310, don't power on after replacing PA | pali | Nokia Hardware & Hardware Repair | 16 | 05-31-2002 14:29 |
C35 don't power on ! 1st must connect charger after that ON ??? | Svetli | Siemens Hardware Repair Area | 2 | 04-14-2002 09:01 |
