Old 07-21-2004, 13:02   #1 (permalink)
Member: 41880
Thanks Meter: 5
3310 with griffin ON but Not Power On
new it s charge with the charger but it s not power on with the battery . i change the power diode and the botton on it s good
help m pls
Old 07-21-2004, 13:35   #2 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
Hi medreda
I if you say power switch is ok then check track from switch to ccont across switch you should get 3.6v-4.0v and should go to zero on pressing switch if there's no 3.6v-4.0v on switch then track or ccont damaged
Regards D.
Old 07-21-2004, 14:24   #3 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 237
will you prove to change the contact where conected batery and clean the contact of the board please.
Old 07-21-2004, 14:51   #4 (permalink)
Member: 41880
Thanks Meter: 5
is not problem concact because is power on with griffin
Old 08-24-2005, 11:29   #5 (permalink)
Registered User
flechazo's Avatar
Member: 39250
Thanks Meter: 64
xD yes MedReda u have reason
ReGards .. Faisal !!
Old 08-24-2005, 12:46   #6 (permalink)
Member: 62922
i agree with Sir DMD I had also that kind of problem and found out that track from switch to ccont was the problem I found that resistor (cold solder) was the culprit. try to check that track sir maybe it may solve your problem
Help Nokia 3310 Flash Ok But Not Power On sofiame2006 Nokia Hardware & Hardware Repair 20 01-28-2011 14:36
SE K510 flashing with SETool OK, but not power ON aryasa Sony Ericsson 9 06-29-2009 07:33
3310 dead flash ok but not powered on !!!!! mahmudbkr Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 26 09-23-2007 17:47
3310 flash 0k but not power on mozib Nokia Hardware & Hardware Repair 6 07-07-2004 21:49
3310 can flash but not power on?! sergo_zmeia Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-27-2004 21:46
Page generated in 0.14837 seconds with 9 queries
