Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2002 Location: egypt Age: 42
Member: 11466 Status: Offline Thanks Meter: 0 | 3310 insert sim ? hard problem 3310 with insert sim change all ( CCONT , X400 , x203,r220 ,r221,r213,c221,c222,c224,c225 ) all that untel hager and reballing cobba can any body help me on that? regards 4 all |
![]() | #4 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Czech republic
Member: 4454 Status: Offline Thanks Meter: 0 | Did you check if some pin from simreader isnt grounded? V203??? did you clean contacts? If all of these components are OK, it must be PCB or MAD. try to check lines from this components and if you dont find anything, probably MAD is bad.... Wolf. |
![]() | #6 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: MX-KEY is the BEST NOKIA TOOL Age: 44
Member: 17367 Status: Offline Thanks Meter: 16 | insert sim Quote:
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2001 Location: No route to host. Age: 39
Member: 6772 Status: Offline Thanks Meter: 17 | @fone: NONSENSE!!! That is impossible! You may be heated CPU a little or phone was water demaged..... Flash IC has nothing to deal with "insert sim" problem... |
![]() | #9 (permalink) |
Junior Member ![]() ![]() Join Date: Jul 2003 Location: Not h3r3, Not th3r3
Member: 33043 Status: Offline Thanks Meter: 1 | check the voltage at the sim pads (VSIM if i am not wrong, the 1st top lefthand pad of the sim card pads) .It should give one time increse in voltage and down again after u switch on the phone. If there is no one time voltage at VSIM, check the lines to CPU (see the service manual) Had the same probem last week. turns out the glued CPU is making the problem. Sticked some thick sticker on the CPU so it will be pressed against the middle casing/body when screwed. good luck |
![]() | #10 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003 Age: 62
Member: 39601 Status: Offline Thanks Meter: 13 | Quote:
As the phone is able to read the SIM , no need to raise the V203 U mentions, this chip is a quadri zinner diods connets in common of Ground. It is for over volt protection and also for protection from IEMF ( Inversed electro magnetic forces ). Regards Br | |
![]() | #11 (permalink) | |
The same as above as the phone can detect SIM card and communicates with it , accepts some of them and refuses some of them . That means that the SIM card interface module to the ccont is working normal ( may be the problem is 3 or 5 volts - but 1800/900 Mhz is not SIM module's matter !!) Regards Br | |
3310 Insert Sim card with sim card in side | uwenk98 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-25-2003 17:28 |
3310 - Insert SIM - SW problem | din | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-08-2002 05:38 |
3310 insert sim problem | unlockerbh | Nokia Hardware & Hardware Repair | 2 | 01-28-2002 06:50 |
Nokia 3310 insert sim card then contact service.. Please help | DrMobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-11-2001 19:19 |
3310 insert sim after simcard insterted | ARC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-29-2001 17:54 |
