Old 09-01-2004, 11:13   #1 (permalink)
Member: 79725
Thanks Meter: 5
3310 insted of op. name 000 00
i have several 3310 with no netowk found after 2 min of search
and when do the set factory set it give 000 00
on lcd in stead of op. logo
i change the (cobba and hagar and vco and ccont and antenna switch)
and still same??
Old 09-01-2004, 11:54   #2 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 235
becouse your product code or imei number is ?????????????
you must see better this .
solution is to write a imei number or product code
or to change flash ic
best regards keany
Old 09-01-2004, 11:54   #3 (permalink)
Member: 55412
Thanks Meter: 20
well u have done so much
but i had to ask have tried flashing it with verigin ?
Old 09-01-2004, 12:01   #4 (permalink)
Yoda_Brno's Avatar
Member: 40423
Thanks Meter: 5
Keany> i respect u, but i had the same problem with reballed COBBA... it was used one. When i had used new one, then flash, recalculate, imei change.. phone worked...
Old 09-01-2004, 12:50   #5 (permalink)
eeprom_flash's Avatar
Member: 58599
Thanks Meter: 2
@ mtmc in evrything u change dont forget last step.. flash fone
Old 09-02-2004, 11:17   #6 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 235
@yoda brno
i respect you too
and all here
but with a 3310 with 5 zero in display is product code missing
and i must do it very simple only write in 5 sec with wintesla .
in your case you have resolve it when you have flash the phone and have recalculate imei .but in his case when he has change all the parts and its the same he must write a product code and imei if it is missing .and at the end if he fails all these ways and the phone is with the same problem , he must change the flash ic and his problem is superated with sucesfool .
best regards to you
keany
Old 09-02-2004, 17:13   #7 (permalink)
Member: 79725
Thanks Meter: 5
Re:000 00
hi
i change the cobba new and orignal
and the sw i do full flash and change the imei
Old 09-10-2004, 03:10   #8 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
1-flash phone with full flash (MCU+PPM+PMM)
2-change IMEI (restore)
3-unlock
4-update FAID
5-full factory
good luck
@Genie Genie is best for flashing? Can i use Genie for flashig insted of other tools? Jani-Jan Genie Universal 6 08-20-2009 11:24
Why delete my post insted of solve my problem. Kiranmistry Universalbox 7 07-22-2009 23:03
how can i use Mozilla insted of internet explorer?? invite Smart-Clip 8 04-06-2009 11:31
Active number display insted of operator logo? analabri Sim Cloning and Scaning 8 06-06-2005 07:09
network: 000 00 ReviveR Nokia Hardware & Hardware Repair 13 07-20-2004 22:25
Page generated in 0.32954 seconds with 8 queries
