11-08-2002, 13:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | 3310 LCD no display and sometimes blur What is the problem. At first, the prob is the PA of the phone is burnt due to charging but already replaced and evrything works fine except this LCD blur and now no display at all. Those who know the answer please reply here. Thank you very much. |
11-08-2002, 16:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | hooi76 Most this problem is LCD connector to PCB! try to replace that connector and clean PCB as well ! also check at VBB on C413 , 2.8V ! and check Vout at C410 , C412 Willy |
11-08-2002, 17:42 | #3 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | it's not the LCD, i tried with a good lcd from my working phone, and it's still de same. Does the CPU affected? I tried to reheat that twice, but still de same. Thanks for your kind attention. |
11-08-2002, 17:56 | #6 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | hooi76,,, did you real check that VBB i told you ? if VBB is ok, then ,,,,,,,,,,,, return it to customer or try to replace MAD,,,, every thing has "first time" Willy |
01-09-2009, 10:38 | #9 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 446881 Status: Offline Thanks Meter: 707 | Your Problem Is 100% Solved here. Just check this out. Nokia 3310 Lcd Display ways Problem Mobile Repairing Picture Help If you like the post please HIT THANKS BUTTON |
01-09-2009, 11:04 | #10 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: punjab ,jalandher
Member: 672494 Status: Offline Thanks Meter: 109 | 3310 lcd soloution Quote:
pin 1-2.8v pin2-0 pin3-0 pin4-2.8v pin5-2.8v pin6-0 pin7-0 pin8-2.8 chek the voltes ok | |
01-09-2009, 13:42 | #12 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Medan - Indonesia Age: 43
Member: 233686 Status: Offline Thanks Meter: 50 | Quote:
try change C410 n C409 .....It's place beside the switch on-off.... | |
k850 no display and no light on lcd...!!! | natlifs | Sony Ericsson | 12 | 11-22-2011 07:41 |
w910 no display and lcd light | kahn1218 | Sony Ericsson Hardware Repair | 3 | 02-27-2010 22:33 |
Help V6 No Display and No Light on LCD | gravity06 | Motorola Hardware Repair | 2 | 01-11-2009 16:14 |
6100 lcd blue new lcd no display some blue lcd | canliyayin | Nokia Hardware & Hardware Repair | 12 | 01-09-2009 09:04 |
3100 lcd - no display and then got display problem. | hooi76 | Nokia Hardware & Hardware Repair | 5 | 03-15-2006 17:41 |
