05-19-2003, 23:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | 3310 low batt I have upgraded soft... no solution, flashed 3315... no solution I have changed P.A. but still same problem what can I do? I want to change three small capacitors, some web pages says that this is the solution but I don't know where can I buy new capacitors to replace thanks and sorry for my english best regards |
05-24-2003, 10:51 | #7 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | ok, I will try with other battery... If no solution must I change ccont? could be posible that new P.A. have same problem that old P.A. and with other change problem will solved? to recalibrate with wintesla I need pkd1 dongle, isnt it? scheme is free now? thanks thanks thanks regards |
05-24-2003, 20:12 | #8 (permalink) |
Freak Poster Join Date: May 2001 Location: Czech republic
Member: 4454 Status: Offline Thanks Meter: 0 | first of all change battery. ccont: try this, there is chance that new ccont is calibrated near your working area. PA: possible is everythink, but it isnt very probably... PKD1 dongle isnt free and I think it never will be... Wolf. |
05-25-2003, 00:30 | #9 (permalink) |
Guest
Posts: n/a
Member: | 1, Clean/replace battery connector 2. Clean/replace battery 3. Change PA 4. Change Antenna switch 5. Rehot HAGAR, COBBA, TXDetect parts. How to check is TXDetect working properly ? Activate net monitor, check is TXPWR changes from 05 to other value - eg 07, 09, 12, etc. I sow many phones with only 05 TXPWR, so, in few cases, only calibration trick helped - Start wintesla, calibration, TX power, click on 05, and decrease decimal value - it's usualy 0.8XX, set it to 0.600, and check base level calculation, click calculate, and save. So, your phone will work at lower TX level, and your battery will be ok . . . |
05-25-2003, 16:29 | #10 (permalink) |
Junior Member Join Date: Apr 2003 Location: Shenzhen, China
Member: 27654 Status: Offline Thanks Meter: 0 | Try to test your battery. I know somewhere have good battery tester for all kinds battery. Please don't put here link or pubblicity for sell here. Last edited by Pandemonio100; 08-11-2003 at 19:02. |
05-25-2003, 23:52 | #12 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | now I have a lot of possible solutions for the problem, thanks to all posters but I have some questions... pkd1 dongle scyheme is not free? I have a scheme and binary files for pkd1 dongle... it is a fake? in other case, is possible to use wintesla cracked, isnt it? @GSMWolf: is necessary to change ccont? is not possible to calibrate ccont withouth change it? ... reflow ccont could help? thanks! |
05-26-2003, 07:37 | #13 (permalink) |
Member: 4454 Status: Offline Thanks Meter: 0 | sure that it is possible to calibrate ccont... but the problem shouldnt be in calibration....CCont should be bad... If you change it, you are 100% sure that problem with ccont is solved..... and if this dont help, you must find problem in another part.... Wolf. |
nokia 3310 low batt | barthosyn | Nokia Hardware & Hardware Repair | 16 | 08-31-2007 18:30 |
Low batt with Nokia 3310 | micka22 | Nokia Hardware & Hardware Repair | 13 | 05-30-2004 07:08 |
Help!3688 Low Batt!! | Mikimiao | Motorola Old Legacy (EMMI) | 0 | 08-23-2002 18:43 |
S35 low batt always.... | CellM@n | x1x to x45/x50 | 12 | 07-19-2002 01:14 |
Allway low batt on 2618s | Jeroen | Old Ericsson Phones & Sony Phones | 1 | 05-26-2001 21:21 |
