03-04-2003, 19:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2001 Location: somewhere Age: 41
Member: 4839 Status: Offline Thanks Meter: 0 | 3310 low standby TO WILLY |
01-24-2004, 08:49 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | TX power calibration is so important in this cases. May be you must reduce power level 19 and 5.But before this read low standby.operation section on repair hints.if you dont have just check PF CCont and this caps C570-c563-c564-c233-c527-c575-c597 |
01-25-2004, 09:17 | #3 (permalink) |
Member: 12724 Status: Offline Thanks Meter: 30 | I forget this:First check if phone goes off even with a full batery in 30-60 second,if yes 99% PA.Some times sw ant if not then continue as below check if charging is ok,put charger and remove.if phone continu to charge with out charge or phone can not determine charger second time,then it is chrge problem if not then: TX power calibration is so important in this cases. May be you must reduce power level 19 and 5.But before this read low standby.operation section on repair hints.if you dont have just check PA CCont and this caps C570-c563-c564-c233-c527-c575-c597 |
3310 Low Standby Time | .:SARCAR:. | Nokia Hardware & Hardware Repair | 2 | 12-23-2006 09:25 |
Low standby problem...help~ | mild7 | Sony Ericsson | 10 | 06-23-2003 11:19 |
8210 low standby | .:*CHENNAI GSM*:. | Nokia Hardware & Hardware Repair | 15 | 02-08-2003 11:37 |
Again, 3310 to Willy .... and everyone !! | CellM@n | Nokia Hardware & Hardware Repair | 3 | 12-06-2002 19:20 |
3210 low standby time battery easily drain??? | eureka8888 | Nokia Hardware & Hardware Repair | 2 | 05-07-2002 11:01 |
