Old 01-11-2005, 05:18   #1 (permalink)
Member: 81153
Lightbulb 3310 Mbus Error
Hello Friends,
I have received 2 pcs of 3310, and here are the problems they are showing
All of them were dead..
I tried to flash with ufs3 flash file 5.59 and I can flash mcu and ppm properly, but when it gets to updating faid, it does not turn on and the message says.. mbus error. I cannot perform any mbus command on the phone.
The second phone, I can only erase the flash, I cannot write, the message says write error and some address of memory. I reballed the Flash Ic, but problem remains...
My cable and software are good, as I can do mbus commands on other 3310 phones..
In some post by Mr. Willy, I read that Mbus has to be pulled high....Can anyone explain how I can check that? I do not have an oscilloscope.
Please...any help in this matter will be highly appreciated, as I want to have a better understanding of this problem.
Best Regards,
Raja3333
Old 01-13-2005, 15:09   #2 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,296
try to check if the flash version you write is stored in flash ic. if not try to reflow or change the ic. or mind to change other lower flash version .
if writing is good check your power ic or reheat it
Old 01-13-2005, 21:06   #3 (permalink)
tanucu04's Avatar
Member: 71633
Thanks Meter: 2
Try to rohoot or change RAM and FLASH ic.
Old 01-13-2005, 21:12   #4 (permalink)
dzunlocker's Avatar
Member: 79640
Sonork: 1577251
Thanks Meter: 236
Hi, i think that Phone's RAM is damaged
Old 01-14-2005, 01:58   #5 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
1. if it'a eerase and not write it's problem by ram chek resistant near ram it's damage change it it will be ok
2. for mbus problem chek coba mostly it's probem by coba rehot it or change it
GooD Luck
*******************Azam****************
Old 01-15-2005, 18:41   #6 (permalink)
Member: 81153
half solved!
Hello friends!
My problem is half solved...
I changed the flash ic, got it from another dead phone...
and the phone took a full flash and even mbus functions! I was and am able to switch on the phone, but it has contact service...
I tried another full flash... but still contact service..
I changed the cobba and reflashed, but still contact service.
Eeprom tools says cobba serial failed.
ONE MORE THING.....the flash IC which I got from the other phone....it had version 6.33 of software in it...so maybe it is not compatible with my phone?
maybe it needs a flash ic from a lower version phone?
please guide and advise.
ANYWAY===at least it switched on!!!!!!!
Regards
Raja3333
Old 01-17-2005, 00:57   #7 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
Originally Posted by raja3333
Hello friends!
Regards
Raja3333
U MUST USE LOWER VERSION IF U R SET WAS LOWER VERSION
IF HIER U MUST USE HIER VERSION FLASH IC
Old 01-17-2005, 02:54   #8 (permalink)
ics_igrec_zet's Avatar
Member: 55427
Thanks Meter: 7
From what i have read since now, u had only bad flash ic or bad solder under flash ic. But now situation is differit now u have two problems:
1.flash ic
2.COBBA
Let me tell u why; first after u changed flash ic and flashing was succesfully but CS, u SHOULDN`T do anything to cobba, successfull flashing don`t mean that flash ic is ok.
Try to solder a new cobba because new ic`s come with ready made pin`s
Try same thing with flash ic, after this opperation reflash phone and should work, NO MATTER WHAT VERSSION u put inside,
I wish u luck, because u`ll needit,
BR, xyz
Old 01-17-2005, 18:04   #9 (permalink)
yoya's Avatar
Member: 80255
Thanks Meter: 13
For "contact service" check R114 near by cobba posibile muved from contacts when you changing cobba
Old 01-18-2005, 19:37   #10 (permalink)
Member: 81153
Thanks!
Thanks for your replies people!
I will do as advised, and then post results again,
Thanks and best regards,
Raja3333
8210 with Mbus Error Laser Nokia Hardware & Hardware Repair 5 12-07-2004 08:08
CHeap Flasher MBUS error AlQuds Nokia Digital Core Technology 4 ( DCT-4 ) 6 07-01-2003 00:41
3310 MBUS problem .::AkhavanGSM::. Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-25-2002 09:52
Nokia 5510 - 3310 MBUS Cable problem diris Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-14-2002 16:15
8210 Mbus Error Laser Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-12-2002 09:28
Page generated in 0.37653 seconds with 8 queries
