Old 11-27-2001, 13:11   #1 (permalink)
Cheater -Don't Deal with him-
Member: 7250
Sonork: 100.1575042
Thanks Meter: 440
Unhappy 3310 mic dont work
i try to change mic but problem not solved!!!<br />how i can repair my phone
Old 11-27-2001, 20:25   #2 (permalink)
Moc
Member: 6099
Post
I have some problem, can any one help....
10x
Old 11-27-2001, 21:12   #3 (permalink)
mirko's Avatar
Member: 2993
Thanks Meter: 9
Cool
hi at all..<br />check if mic contact on pcb for dirty or oxide<br />you can try to check first headset connector<br />sometimes it is broken, after check the component next mic contact ..<br />the mic path is mic headset conn cobba ic,<br />for last solution try to resold ccont ic and cobba ic whit ir solder.
Old 11-28-2001, 02:12   #4 (permalink)
Member: 7642
Hi,<br />its easy you have to change the serial MIC Condensator which is located in the top right corner (near Cobba) it has value 2x33nF and it is broken od damaged (working 100%) tested.
Old 11-28-2001, 16:15   #5 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
Post
hey bro;
try air-tech's solution that may solve your problems.i've tried it b4 and works 100%.
<br />best regards to all...........
<br />----------------------------
<br />kick butt first,<br />take names later <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
Old 11-28-2001, 22:26   #6 (permalink)
j2000's Avatar
Member: 6349
Thanks Meter: 6
Talking
Hiii just try rehot COBBA IC (10 second) and it can solve many problem of MIC and Speaker....
Old 11-29-2001, 18:33   #7 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
TO J2000
i don't think that will work at this time co'z i've tried it many times but still no mic.
the only solution to that is to try air-tek's solution first then if nothing happens then i'll tell gsmlord to try your solution.
best regards........
<br />--------------------------------
Old 11-29-2001, 23:28   #8 (permalink)
Member: 7327
Thanks Meter: 12
hello m8s
what AIR-tech & markie said is the solution , treid & worked 100% .
kind regards .
Old 11-30-2001, 13:48   #9 (permalink)
Member: 4675
Thanks Meter: 7
Post
can u tell me what part number, thanks
Old 11-30-2001, 21:52   #10 (permalink)
Moc
Member: 6099
Post
In my case after rehot the cobba i get good sound but only for one call, and now another person ear me with very low sound ....
any soluction for this....
Old 12-30-2001, 16:16   #11 (permalink)
Member: 6950
Thanks Meter: 4
Post
i have the same problem and i tryed the solution<br />but it won't work for me.<br />If i plugin a headset then it sounds ok<br />is it possible to connect to wires from headset to mic.<br />does someone know wich two point's to connect to mic from connector of phone?
Old 12-30-2001, 21:28   #12 (permalink)
Member: 7168
Thanks Meter: 3
Post
[quote]Originally posted by AIR-tech:<br /><strong>Hi,<br />its easy you have to change the serial MIC Condensator which is located in the top right corner (near Cobba) it has value 2x33nF and it is broken od damaged (working 100%) tested.</strong><hr></blockquote>
ples goto <br /><a href="http://www.inside-gsm.com/Nokia/Nokia_3310/Inside_Nokia_3310/Component_side_description_Nok/component_side_description_nok.html" target="_blank">http://www.inside-gsm.com/Nokia/Nokia_3310/Inside_Nokia_3310/Component_side_description_Nok/component_side_description_nok.html</a><br />and which number i chang
Old 12-31-2001, 11:41   #13 (permalink)
Member: 4675
Thanks Meter: 7
Post
is that part number c120?
Old 01-02-2002, 15:53   #14 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Ok, i've tested personally by my self and it's the cobba ic (usually water damaged and it's oxidise inside the cobba ic's balls), so my choice is to take out the cobba ic and then clean the pcb and the cobba ic with thinner and resolder it back... and the mic works perfectly...hope this can solve you guys problems <br /> Cheers
Old 01-02-2002, 20:00   #15 (permalink)
Member: 7250
Sonork: 100.1575042
Thanks Meter: 440
can u tell with which equipment u can resolder cobba ic?
The Following User Says Thank You to gsm-lord For This Useful Post:
HELP LG CHOCOLATE mic dont working makkah mobile LG 10 06-06-2010 21:19
nokia 8600 mic dont work! s-mobileturkey Nokia Hardware & Hardware Repair 0 10-20-2008 12:34
c100 mic dont work mhamad-198 Samsung Hardware Repair 2 05-08-2007 15:33
k300 mic dont work svedok Sony Ericsson Hardware Repair 2 11-15-2006 19:46
Nokia 3310 Mic not working YamahaR1 Nokia Hardware & Hardware Repair 5 11-15-2002 22:19
Page generated in 0.21319 seconds with 9 queries
