12-30-2004, 19:30 | #1 (permalink) |
Major Poster Join Date: Sep 2004 Age: 54
Member: 81153 Status: Offline Thanks Meter: 0 | 3310 Network Plays I receive many pcs of 3310, 8210 which have network for a few seconds, then loose network, then again catch network in 5 seconds! I have checked the vbatt to PA, heated the small components like filters, couplers, heated the antenna switch, checked the path oh the components in RF section according to schematic, all ok, but still problem stays. Now I want to know, if there IS network and it comes and goes, can it be a problem of the antenna switch? because as I understand if there is network, the antenna switch is ok... Also, some posts mention attaching a false antenna to the pcb. How to do that, in 3310 8210? PS: I would like to contribute that in network problems, FIRST check VBATT to pf, it can solve the problem many times. Also, in 3310, if you have a dead set, check resistor r224 it should have 10 kohms. If not, change it. This is my small ( very ) small contribution to GSMHOSTING forum.... I have started repairing handsets with the help of the people on this forum, and have benifitted a lot from here! Keep it up! Raja3333 |
12-30-2004, 22:35 | #3 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: GermanY
Member: 38922 Status: Offline Thanks Meter: 35 | Quote:
Never change without check! This is not proffesional. The first thing what we can see in DCT3 (also in DCt4) is that we at Receive problems first check MANUAL NETWORK search. Post the result here and we can say whats you do for the result. GreetZ | |
12-30-2004, 23:00 | #4 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @raja3333 This fault is most properly due to 32 KHZ Crystal or 26 MHZ reference osillator being defunct ! I would take a scope or counter to measure those 2 Regards |
12-31-2004, 05:22 | #5 (permalink) |
Member: 81153 Status: Offline Thanks Meter: 0 | @Cyberoptik Hi, I have checked manual search, it shoiws all networks, 900 and 1800, it can also select the network manually as well as on automatic, but the network plays, meaning it suddenly disappears for 5 seconds and then comes back @GsmCoolhawk I will have to buy an oscilloscope to check this... Can you suggest the minimum configuration oscilloscope required? Do computer based oscilloscopes work for mobile testing purposes? Also, is it very expensive? I am located in India, and I doubt that oscilloscopes will be easily available .... Reagrds, Raja3333 |
01-02-2005, 03:02 | #6 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | @Raja3333 if it's come back after 5 sc this problem mostly in antina switch change it or do jump and many time it's show u the antina switch is good but it's not good u must change it and then reflash it with banana 4.77 becous this will do good format and reflash it with flash file 5.13 tested and work 50% for me in my 3 year expiruns maybe help u too i repairt this problem over then 40% in saudi arabia in madinah **************Azam**************** |
05-27-2006, 15:50 | #9 (permalink) | |
Insane Poster Join Date: Apr 2006
Member: 255625 Status: Offline Thanks Meter: 13 | thanks Coolhawk Quote:
Replace 32 KHZ Crystal Problem solve 100% regards | |
Nokia 3310 melody plays very slow | SVH | Nokia Hardware & Hardware Repair | 14 | 01-13-2005 17:22 |
3310 network? | gsmsalers | Nokia Hardware & Hardware Repair | 8 | 07-04-2002 07:18 |
6210 & 3310 Network Signal only for few seconds | douda | Nokia Hardware & Hardware Repair | 6 | 06-25-2002 18:02 |
3310 network problem | emmyale | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 05-19-2002 09:40 |
3310 network problem | gsmkid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-09-2001 21:21 |
