Old 09-23-2004, 16:41   #1 (permalink)
Member: 81153
3310 network problems!
Hello Friends!
I have just started repairing handsets, and am facing problems, particularly with 3310 network. I have a few handsets that leave network withing 10 seconds of switching on...
I have gone through Keany's thread, found it to be very helpful, and have tried most of the options mentioned there, but the problem remains....
Now I am wquite sure that many of you must be facing this same problem, I would like to know how you people handle such problems...
I have tried reheating the PA, changing it, changing the antenna switch, reheating the Cobba, the entire board, checked for continuity between vbatt and pf, etc, but no solution.
I would like you people to share your own experiences with me on this topic please...
Best Regards,
Raja3333
Old 09-24-2004, 16:13   #2 (permalink)
Registered User
flechazo's Avatar
Member: 39250
Thanks Meter: 64
change a PA and Try to set FAID
ReGards ..
Old 09-25-2004, 09:15   #3 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Exclamation
Yo man. don't change PA or what they say. i was having the same problem.
follow steps :-
1) Flash phone using FuBu Flash(or your modded flash)
2) Change IMEI
3) Reset SP locks
4) Reset Full factory or SFR.
5) Update FAID
normally, MSID changes when imei is changed or sp lock is reset. your phone should be running up again.
Old 09-25-2004, 09:22   #4 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Ok. if your prob doesn't get solved. try my previous posts:
http://forum.gsmhosting.com/vbb/show...5&goto=newpost
Old 09-26-2004, 08:14   #5 (permalink)
Member: 81153
Thanks Friends!
I have tried to change PA, updated software, Faid etc.
No solution.
How do I jump the antenna switch? Is any diagram possible? I would really appreciate any help I get.
Regards,
Raja3333
Old 09-26-2004, 09:52   #6 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
heat the pf and the switching antenna and also chek the flower
Old 09-26-2004, 10:05   #7 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
Originally Posted by raja3333
Thanks Friends!
No solution.
Regards,
Raja3333
For the first activate netmonitor and after power on run it in 1st menu and write what can you see there with all changes in first 10seconds
5o
Old 09-26-2004, 12:34   #8 (permalink)
Member: 81153
Good Idea!
I willtry it and report back tomorrow...
Great people here! Thanks for your help people!
Best Regards,
Raja3333
Old 10-07-2004, 06:07   #9 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
go to www.gsmschwantz.com
3310 network problems jsec2 Nokia Hardware & Hardware Repair 3 03-19-2003 18:17
3310 network problem hs_ Nokia Hardware & Hardware Repair 3 10-21-2002 18:06
nokia 3310 network problem tgsm Nokia Hardware & Hardware Repair 8 09-29-2002 18:12
3310 network problem emmyale Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-19-2002 09:40
3310 network problem gsmkid Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-09-2001 21:21
Page generated in 0.18002 seconds with 10 queries
