Old 03-03-2002, 00:48   #1 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
3310 No Lcd Shown
Hi
I have 3310 lcd shows not anything,
sometimes when i power on it shows some dots in lcd......
i changed lcd , no result
also rehot Phone RAM , still no result
any solutionss?
Old 03-03-2002, 22:31   #2 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Really no solution?????!!!!!!!
there's really no solutions??????
or there's nobody to help???
Old 03-04-2002, 06:25   #3 (permalink)
Member: 7939
Thanks Meter: 2
Have the same on a 3330 it sitting in service center waiting to be done if I find out what was done will post.
Old 03-04-2002, 06:39   #4 (permalink)
Member: 9254
Thanks Meter: 4
Hi
you can try cleaning lcd pcb contacts , flashing s/w and checking contrast level.
If still doesnt work after changing lcd (with one that u know works)
You will need a service manual ( circuit diagram + component layout ) and some way of powering up pcb outside housing for voltage measurements :-
check VBB 2.8 VDC at C409/413.
check that voltage ay J314 is 2.8VDC (lcd reset) - if line short-circuited to ground will cause lcd not to work.
Also check that voltage at both sides of R306 is 2.8 VDC.
If all above values are ok, then you can bin it or use for spares , because MAD2 IC or PCB is probably faulty
Hope this helps
Old 03-04-2002, 06:42   #5 (permalink)
Member: 7939
Thanks Meter: 2
some one read the manual, did upgrade and cleaned board and reheated as well
Old 03-04-2002, 08:08   #6 (permalink)
hacker1gsm's Avatar
Member: 5113
Thanks Meter: 10
i told u ARC there is no solution until now
but it will be soon
regards
N81 8GB No data shown on the screen. ain488 Nokia Hardware & Hardware Repair 1 08-27-2009 04:10
urgent credit taken but no code shown infogsm SAGEM JTAG UNLOCKER 3 01-08-2009 23:51
3310 no voltage on last piont on lcd ? iyass Nokia Hardware & Hardware Repair 9 12-24-2003 17:21
3310 No Light No Sound And No Vibtabing!!!!!!!! robbiesl42 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-31-2002 02:20
3310 no led light at lcd eureka8888 Nokia Hardware & Hardware Repair 5 05-30-2002 10:26
Page generated in 0.19146 seconds with 9 queries
