06-12-2001, 03:09 | #3 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | Check your Imei Number...is it correct?? Try to reflash it. If no improvement, try to use HAKKO in Hagar Section ( Be carefull). It is completly hardware problem. Some Capacitor not work properly. Mail me ... Regards :: Note : PLS HELP Siemens Service Manual |
06-12-2001, 15:21 | #5 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Quote:
Hello Du. I've got Lots of 3310 with no network, First they trouble me lot...but now I over come this. I'm doing like this. The problem is in Transmission (Tx). Some time There is dry Soler at IC NMP70731. BGY IC near 13 MHZ(Section No. 2 from Up side). U should have Hot-air gun with big nozzle. And if not solved by dry solder then u've to replace it(need BGY Tool-kit) . But It must be solved by dry solder. So Best of Luck. Post your results here. | |
06-12-2001, 15:57 | #6 (permalink) | |
Freak Poster Join Date: Nov 1999
Member: 683 Status: Offline Thanks Meter: 0 | First try to search network ( press menu 6-2-4-2). There are at least 3 posible anomalies you must observe. 1. The phone finds a incomplete network list. 2. The phone cannot find any network. 3. The phone finds a complete network list but no access. So which one is your problem? Quote:
Best Regards. | |
06-12-2001, 20:32 | #7 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Some where around the world.
Member: 3845 Status: Offline Thanks Meter: 2 | Try to change hagar ic must be fast not over heat.Work 50%.Or rework hagar ic or cobba maybe dry solder.But must have bga tool like ball planting tool. |
06-13-2001, 05:30 | #9 (permalink) | |
Member: 3845 Status: Offline Thanks Meter: 2 | Quote:
Ball planting tool is like rework bga.When you take out bga ic your solder ball can't use[damage] so you use the tool to make a new solder ball and solder back to board.Try to use this tool very useful tool.Very famous in Asia Country. Have any question. That all. That all.Have any question. | |
06-19-2001, 03:26 | #14 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | Completely hardware problem, the problem is Chip Capacitor ( some capacitor near hagar ) you can pull it out and change it, or just remove it and put it back again. Use Hakko 850, with very low air pressure. This information is 100% work, trust me... Note : Any Siemens Service Manual ???? Regards |
F200 User Fault On Illegal Trial and NO NETWORK how to fix? | jap_line | UST Pro II | 1 | 11-23-2009 15:54 |
w810 no network.. how to fix this problem? | ryumahon | Universalbox | 5 | 07-19-2007 00:48 |
SE m600i says... "Searching" no network, how to fix?? | wingh2daizzo | Sony Ericsson | 3 | 05-24-2007 09:10 |
8310 no network - how to fix up? | uu1dx | Nokia Hardware & Hardware Repair | 2 | 12-25-2002 20:51 |
8210 no network - How to repair it ? | unlockphone | Nokia Hardware & Hardware Repair | 14 | 07-15-2001 00:17 |
