3310 no power Hi all, Can't power up nk3310. I rehot ccont, replace G502, B200 and Hagar. Power button is ok. Flashing ok, don't charging. br, Deepx |
Yess I have same problem Please Help.................. |
try to replace ccont and cobba |
replace ccont.....................:)) |
I use same IC ccont and cobba to the others phone work normal |
i think it is not the problem of ccont because he flashed it..if there is problem for cocnt how he can flash..so try by changing flash,it might be due to flash complaint |
Write fubu then read,open in hex editor and compare>If not same then flash ic is bad,if same try to change RAM. WBR dean |
Hy deepx I think you use the eeprom tool, read new double eeprom with ok phone and write on your faulty phone may be phone goes to ON other wise you change or rehot the RAM IC. May be possible fash hardware faulty. |
