Old 04-15-2004, 20:02   #1 (permalink)
Member: 13696
3310 no power
Hi all,
Can't power up nk3310. I rehot ccont, replace G502, B200 and Hagar. Power button is ok. Flashing ok, don't charging.
br,
Deepx
Old 04-30-2004, 12:06   #2 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
Yess I have same problem Please Help..................
Old 04-30-2004, 12:28   #3 (permalink)
renejeic's Avatar
Member: 53684
Thanks Meter: 11
try to replace ccont and cobba
Old 04-30-2004, 12:39   #4 (permalink)
megone's Avatar
Member: 31594
Thanks Meter: 13
replace ccont.....................)
Old 04-30-2004, 18:46   #5 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
I use same IC ccont and cobba to the others phone work normal
Old 05-01-2004, 08:10   #6 (permalink)
Member: 59064
i think it is not the problem of ccont because he flashed it..if there is problem for cocnt how he can flash..so try by changing flash,it might be due to flash complaint
Old 05-01-2004, 09:26   #7 (permalink)
kojote's Avatar
Member: 33472
Thanks Meter: 17
Write fubu then read,open in hex editor and compare>If not same then flash ic is bad,if same try to change RAM.
WBR
dean
Old 05-02-2004, 10:32   #8 (permalink)
Member: 58466
Thanks Meter: 19
Originally Posted by deepx
Hi all,
br,
Deepx
If u r able 2 flash it means pwr supply line is ok.So only problem lies with flash ic .Change the flash ic &Do a flash.
Old 05-02-2004, 10:55   #9 (permalink)
Member: 58466
Thanks Meter: 19
Hi all,
br,
Deepx
I faced the same problem once.And the problem was in the PA.It had become short.And set was not on.When the PA was removed the set became ok.But the problem I face now is When I changed it with a new 1 the PA got short again.Any help from learned members.
Old 05-02-2004, 11:51   #10 (permalink)
Member: 63494
Hy deepx
I think you use the eeprom tool, read new double eeprom with ok phone and write on your faulty phone may be phone goes to ON other wise you change or rehot the RAM IC. May be possible fash hardware faulty.
3310 no power and no charging haller Nokia Hardware & Hardware Repair 4 07-11-2005 14:43
3310 no power after flash conac Nokia Hardware & Hardware Repair 4 03-31-2005 20:44
3310 no power after liquid damage ash1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 09-12-2004 13:52
3310 no power iliescu_l Nokia Hardware & Hardware Repair 1 10-10-2002 16:51
3310 no power flash Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 09-13-2002 15:11
Page generated in 0.21081 seconds with 9 queries
