Old 03-04-2005, 14:45   #1 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
3310 nokia No network or 00000
Hi ! I have nokia 3310 when searching manually for network it says "NO NETWORK" and when I reset phone factory settings it shows instead of networks name Zero's 00 000. Plz help me I have 4 phones like this faults I Have reballed cobba, ccont, hagar, change antenna switch. but nothing worked. flashed the phone with good flasher but no result. I havent touched the ram and flash ic will they be the reason for No Network ??
The Following 2 Users Say Thank You to amitks_in For This Useful Post:
Old 03-04-2005, 15:29   #2 (permalink)
OLYMPIOS's Avatar
Member: 93568
Thanks Meter: 44
your answer is to the first thread!!!! open and read !!! have pictures Too!
The Following User Says Thank You to OLYMPIOS For This Useful Post:
Old 03-04-2005, 15:32   #3 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,116
13 mhz change?????????
The Following User Says Thank You to sevgigsm For This Useful Post:
Old 03-04-2005, 19:20   #4 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
What is 13 mhz ?? sorry tell me the name or location of this part Thank u Sir
The Following User Says Thank You to amitks_in For This Useful Post:
Old 03-04-2005, 19:30   #5 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,116
soryy
13- 26 mhz change G502
The Following 2 Users Say Thank You to sevgigsm For This Useful Post:
Old 03-05-2005, 01:36   #6 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
Hi man! If you reseted phones using twister, it's a SW problem, just write virgin eeprom 3310, then repair imei and set faid. Be careful with UI options using twister.
The Following User Says Thank You to Masta G. For This Useful Post:
Old 03-05-2005, 02:44   #7 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
No I have reset the phone manually from meanu in the phone settings and full factory settings. I have written the pm. a good one. I think the problem is in circuit of power supply to antenna switch and pfo/pa supply will not be full to the network section of the board, tell me how to check power supply is ok to antenna switch pfo/PA or in network section.
Old 03-21-2005, 23:56   #8 (permalink)
gama_cell99's Avatar
Member: 92067
Thanks Meter: 10
I already changed but still no network.........?????
The Following User Says Thank You to gama_cell99 For This Useful Post:
Old 03-16-2006, 01:58   #9 (permalink)
Member: 79050
I'm having the same frustrating problem with a 3310. It got to the point where I actually swapped the CCONT, COBBA, HAGAR, and 13Mhz crystal from a GOOD phone, but still no network after 30-40 seconds. From the DCT3 network solutions, I can see the problem is COBBA or 13Mhz Crystal, but both are from WORKING set .... any ideas please ?
The Following User Says Thank You to mikevee For This Useful Post:
Old 03-16-2006, 10:34   #10 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
hi all!
@mikevee: change PA, m8 (-:
Old 02-12-2010, 12:24   #11 (permalink)
Member: 152961
Thanks Meter: 11
I change pa but no result............
The Following User Says Thank You to links pak For This Useful Post:
Old 02-12-2010, 12:30   #12 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
change switch, cobba, write good fullflash, faid and fullfactory.
Old 02-13-2010, 04:24   #13 (permalink)
chetanmaturkar7's Avatar
Member: 986394
Thanks Meter: 168
i solve u r 00000 problem, u change only hager ic.
The Following User Says Thank You to chetanmaturkar7 For This Useful Post:
Old 02-13-2010, 07:50   #14 (permalink)
Member: 975961
Sonork: +91-9897902397
Thanks Meter: 69
change cobba ic
The Following User Says Thank You to ravindrapr For This Useful Post:
Old 02-13-2010, 08:52   #15 (permalink)
Member: 1235001
Sonork: anandh
Thanks Meter: 12
check info for mobile in hwk
in info u can see the coba id
if coba id:00000 causes no network founded but mobile works fine
check coba
The Following User Says Thank You to anandh_lll For This Useful Post:
sigmatel s30 no network or low network.Plz help.... jana1_2008 Chinese Models & Cloned Phones 2 09-07-2009 10:00
just working on nokia on others no network or loose network falak TORNADO - SIM 6 04-28-2008 08:46
3510i no network or no No Access jon2 Nokia Digital Core Technology 4 ( DCT-4 ) 1 09-17-2005 09:51
2600 no network or no acess jon2 Nokia Digital Core Technology 4 ( DCT-4 ) 1 09-17-2005 08:36
Nokia 3310/3330 No network signal blaat Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 07-27-2002 02:35
Page generated in 0.51304 seconds with 9 queries
