Old 03-26-2003, 13:12   #1 (permalink)
Member: 14004
Thanks Meter: 6
3310: phone wont stay ON
I have problem with 3310:
Phone was water damaged, so first i have clenaed it good.
Now, when i try to power it on, phone starts, shows black
screen, then screen goes white, and after exactlly 5 seconds turno OFF.
Nothing happens when i try to connect charger (sometimes - in 1 of 20 cases, it shows bat. indicator for a second, but no charging progress).
I have checked F200, L202, L201, R204, V202, R220, R221, R222 - all OK.
Is it CCONT, CHAPS, or sometihng else?
Old 03-26-2003, 13:42   #2 (permalink)
GazI's Avatar
Member: 20566
Thanks Meter: 29
hi
johny3310 check the phone with eprom tool 4 or winddp
or try to flash
Old 03-26-2003, 15:15   #3 (permalink)
Member: 14004
Thanks Meter: 6
Cannot flash: preloader boot error.
EEPROM tools doesn't help, phone needs to be turned on for this!
Old 03-26-2003, 15:19   #4 (permalink)
Member: 14004
Thanks Meter: 6
another info i just found out: With Ni-MH battery it wont turn on at all
With Li-ion battery turns on, but auto-turn-off in 5 seconds.
strange.
Old 03-26-2003, 18:47   #5 (permalink)
GazI's Avatar
Member: 20566
Thanks Meter: 29
for preloader boot error check flasher pins or clean cotact
hi have you tried this solution for clenaed
http://216.239.39.120/translate_c?hl...air/alkbad.htm
Old 03-26-2003, 20:36   #6 (permalink)
Member: 10125
Thanks Meter: 287
Hey johny3310, It may be the CCOUNT (N201) or may be you can have a defective MAD2 (D300) and since you can't flash the phone, check for a short circuit under the SRAM (D302) or try to reball ccount-mad2 and sram
Old 03-26-2003, 20:39   #7 (permalink)
Member: 14004
Thanks Meter: 6
Flasher pins or OK, contacts are OK. FBUS & MBUS lines on PCB are also OK.
Oh, oh!
That's a very lame metod. I have more professional tools. I have cleaned the PCB with isopropanol in ultrasonic cleaner. And after that i have dried it very good with hot air (tmp min, air flow max).
And, i brushed whole boards very carefully and patiently.....
So, what i can do next?
Old 03-26-2003, 21:07   #8 (permalink)
Member: 14004
Thanks Meter: 6
I hate reballing MAD
i9 engineer menu - now phone wont power on purct Chinese Models & Cloned Phones 8 08-26-2009 23:04
d600 wont stay turned on storm66 SWIFT Platform 0 02-05-2007 14:36
Phone Wont Stay On vladamir NEC 1 08-14-2005 22:41
E398 help!! uRGENT! phone wont turn on mazdaspeed_FC Motorola P2k 3 09-11-2004 23:15
Page generated in 0.23502 seconds with 9 queries
