05-13-2003, 15:43 | #1 (permalink) |
Freak Poster Join Date: Feb 2002 Location: davao, philippines Age: 43
Member: 9398 Status: Offline Thanks Meter: 1 | 3310 poor signal... but with this phone 2 bars max... already replaced PA, antenna switch cobba ccont hagar... any help mates??? tnx br, wamir |
05-13-2003, 16:21 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | try to change the small metal filtersone just under the antenna switch and another on the right side of hagar but normally the problem is from antenna switch only.....try to change it from a working phone.... |
05-13-2003, 16:29 | #3 (permalink) |
Member: 9398 Status: Offline Thanks Meter: 1 | yeah in most cases antenna switch is the prob.. im really havin a hard time with this one.. anyway tnx for ur reply mate.. il try what uve said.. br, wamir |
05-13-2003, 19:42 | #4 (permalink) |
Freak Poster Join Date: May 2001 Location: Czech republic
Member: 4454 Status: Offline Thanks Meter: 0 | which canal in netmonitor are you conected? netmonitor test 1 first munber is number of active canal. If you arent conected with both phones to the same canal, you cant compare intensity of network. Canals with low numbers under 150 are 900MHz high number of canal - 1800MHz Wolf. |
05-17-2003, 03:39 | #9 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Wamir IF YOUR ANTENNA SWITCH IS OK, then try to replace some SAW filter between antenna switch to hager and check 26Mhz TCXO that AFC control by COBBA ! Willy |
8210 very poor signal | bruukz | Nokia Hardware & Hardware Repair | 5 | 03-16-2003 20:34 |
6210 poor signal on both 900-1800 bands | jokkergsm | Nokia Hardware & Hardware Repair | 2 | 03-16-2003 12:26 |
t39 poor signal | hikaru | Hardware Repair by brands | 1 | 07-27-2002 16:01 |
8210 poor signal and network coverage | Budice | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-09-2002 05:13 |
t28 poor signal - what can be done? | sat | Sony Ericsson Hardware Repair | 5 | 11-22-2001 12:14 |
