Old 05-08-2003, 13:53   #1 (permalink)
Member: 14469
3310 power off when call or try to find network
3310 SOME TIME power off - when phone trying search network or making call.
Is it a PA problem ? - PCB clean
Old 05-08-2003, 15:45   #2 (permalink)
Member: 22526
Hi!
I think if just some time turn off try rehot the CCONT with flux.
B.R.
Old 05-08-2003, 16:19   #3 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,393
Change PA,check/change antena swich.Phone will be ok
Old 05-09-2003, 15:38   #4 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
i think the pa
change it
Old 05-10-2003, 11:08   #5 (permalink)
dani146's Avatar
Member: 3812
Thanks Meter: 3
do not forget about this...
Hi,
first verify if battery is ok,
only after that go to PA and Diplexor (antena switch)...
WBR,
Daniel M.
Old 05-10-2003, 22:00   #6 (permalink)
Springer's Avatar
Member: 15909
JUST PA!! 100% . change it!
Old 05-11-2003, 11:17   #7 (permalink)
dani146's Avatar
Member: 3812
Thanks Meter: 3
Springer - don't be so shure
Hi,
Springer, I can show you 3 pieces of 3310 with
same problems and I'll let you change the PA
how many times you want and the problem will persist.
So, don't be so shure about PA. In 60% of cases it was PA but...
Old 05-12-2003, 21:30   #8 (permalink)
Springer's Avatar
Member: 15909
Hi
What i say is PA problem. Of course not 100%. I have been sevice man, i try help for everybody. I meet this problem day per day.
No wrath.
B.R.
Old 05-12-2003, 21:35   #9 (permalink)
Springer's Avatar
Member: 15909
...Sorry my english...
Old 05-13-2003, 05:26   #10 (permalink)
Member: 12398
I think is PA problem
Old 05-13-2003, 10:03   #11 (permalink)
Member: 12724
Thanks Meter: 30
First:Measure the current in sleep modeand also when a call is active.
If there are normal battery is weak.else many component can cause this.PA,CCONT L513 L201,Capacitors in VB line and....
Old 05-13-2003, 23:48   #12 (permalink)
Member: 27721
try to measure current when make a call(should be not higher than 450mA).if current is normal change the batery. if its posible find a Li-Ion batery is much beter.if curent is higher replace pa and reheat PCB in most cases will solve the ptoblem
good luck!
Old 05-15-2003, 19:03   #13 (permalink)
billyuk009's Avatar
Member: 28670
Thanks Meter: 38
CHANGE THE PA .
Old 05-16-2003, 01:43   #14 (permalink)
claudio_gsm's Avatar
Member: 16165
Thanks Meter: 9
the same ...change ... PA ... ...
BesT RegardS ... to all
Old 06-20-2004, 02:51   #15 (permalink)
Member: 5722
no f*****g way!!!!!!!!!!!
i have same problem.without pa works ok but with pa power off when signal comes on start.i try 3 pa new and OEM .but same problem.i've tested pa on other 3310 and are ok.
reball cobba and ccont .USELESS.exchange antena switch.USELESS!!!!
ANY IDEEA?
3310 powered off when sending call jetawo ademola Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 01-26-2005 03:48
Ericsson 2628 power off When Call Raklm Sony Ericsson Hardware Repair 2 01-06-2003 16:18
Ericsson T18 Power Off When Calling 112 ARC Sony Ericsson Hardware Repair 2 12-01-2002 07:43
3310 power off when sending Jt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-24-2002 10:51
8850-8250-3310-power off when detect network!!!!! micmac Nokia Hardware & Hardware Repair 4 06-28-2002 19:14
Page generated in 0.39865 seconds with 8 queries
