-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   3310 Power Problem (http://forum.gsmhosting.com/vbb/f148/3310-power-problem-81318/)
fonetech 04-17-2003 14:01
3310 Power Problem
I have a 3310 here and if I power on the phone its fine BUT as soon as I power the phone down again I have to remove the battery and put it back in before it powers up again
vule 04-18-2003 16:40
Hiya
Is that phone water damaged maybe???
I had same problem and i solved it by cleaning board with ultrasonic bath...
If that does not help check following line: switch - r402 - r221 - ccont...
Also check B200 32768 kHz osc and components around...
Vule
MobiFix 04-18-2003 18:12
I think this is CCONT problem try to rehot or change
shans 04-19-2003 19:06
change the ccont (power ic ) and clean the bord well
gsmsupport
good prices for griffin & sony erriccsson
hulala.[uk] 04-22-2003 11:15
try to ground watchdog and try to switch it on and c what is happening...i had number of phones with faulty PA causing this probleb as well...so check pa...post results
willy 04-22-2003 19:02
Re: 3310 Power Problem
check line from key pay "3" to V414 to power switch !
or try to power off phone by short gnd to keypad 3 center connect , if it make phone off, then it is line cut from pin 3 via V414 to switch !
Willy
travolta 08-30-2005 13:06
3310 strange problem
some1 plss xplain this fone madness,the fone powers on automatically immidiately i insert battery but the power on swicth does not work and if on and i touch any button it goes off,till i remove and put battery again. :confused:
Page generated in 0.18961 seconds with 5 queries
