04-17-2003, 13:01 | #1 (permalink) |
No Life Poster Join Date: Sep 2002
Member: 15837 Status: Offline Thanks Meter: 2 | 3310 Power Problem |
04-18-2003, 15:40 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya Is that phone water damaged maybe??? I had same problem and i solved it by cleaning board with ultrasonic bath... If that does not help check following line: switch - r402 - r221 - ccont... Also check B200 32768 kHz osc and components around... BR Vule |
04-19-2003, 18:06 | #4 (permalink) |
Freak Poster Join Date: Sep 2002 Location: thrissur kerala Age: 45
Member: 16050 Status: Offline Thanks Meter: 0 | change the ccont (power ic ) and clean the bord well gsmsupport good prices for griffin & sony erriccsson |
04-22-2003, 10:15 | #5 (permalink) |
Insane Poster Join Date: Mar 2003 Location: London Age: 41
Member: 23790 Status: Offline Thanks Meter: 0 | try to ground watchdog and try to switch it on and c what is happening...i had number of phones with faulty PA causing this probleb as well...so check pa...post results |
04-22-2003, 18:02 | #6 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310 Power Problem Quote:
check line from key pay "3" to V414 to power switch ! or try to power off phone by short gnd to keypad 3 center connect , if it make phone off, then it is line cut from pin 3 via V414 to switch ! Willy | |
08-30-2005, 12:06 | #7 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 77076 Status: Offline Thanks Meter: 7 | 3310 strange problem some1 plss xplain this fone madness,the fone powers on automatically immidiately i insert battery but the power on swicth does not work and if on and i touch any button it goes off,till i remove and put battery again. |
3310 power problem | gibso | Nokia Hardware & Hardware Repair | 4 | 11-21-2003 18:50 |
3310 power problem | gibso | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-19-2003 22:04 |
3310 Power Problem | douda | Nokia Hardware & Hardware Repair | 3 | 03-17-2003 23:45 |
3310 power problem | andie | Nokia Hardware & Hardware Repair | 0 | 01-17-2003 23:22 |
3310 power problem | feverdj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-23-2002 22:54 |
