11-29-2007, 17:59 | #3 (permalink) |
Freak Poster Join Date: May 2006
Member: 278058 Status: Offline Thanks Meter: 81 | You can let it get powered up by shorting the upper two legs of the power switch terminal with the lower two legs. Than your handset should power on with just inserting battery! |
11-29-2007, 18:44 | #5 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 197916 Status: Offline Thanks Meter: 157 | i thing if u shorting the upper two legs of the power switch terminal with the lower two legs. Than your handset should power on with just inserting battery??? this is a problem!! |
1200 flash ok ui setting ok normal mode ok but not no by power switch switch volt ok | Punit Kumar | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 02-25-2010 12:58 |
3310,8210 Power switch solution. 6610 volume switch solution(NEED HELP) | smartfone | Nokia Hardware & Hardware Repair | 7 | 09-15-2006 06:29 |
3200 power switch, new switch? | sjakie | Nokia Hardware & Hardware Repair | 5 | 02-14-2006 22:58 |
3310 after switching off, will only switch back on if you remove and replace battery | bilbo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-2003 00:41 |
3310 powers on without switch | mohammed | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-2002 14:52 |
