11-08-2001, 16:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2000
Member: 2797 Status: Offline Thanks Meter: 0 | 3310 problems after instaling Blue leds!! regards<br />Me@n |
11-11-2001, 21:22 | #3 (permalink) |
Member: 2797 Status: Offline Thanks Meter: 0 | I think you are right ,I did not have corect leds for this phone (I used smaller ones) and I had to bridge them ,so I used solder to bridge leds. Thank you for your answer MDR<br />regards Me@n |
11-17-2001, 14:33 | #6 (permalink) |
Member: 2797 Status: Offline Thanks Meter: 0 | Everything is all right , phone is working well now , funny thing I did`t do anything and it is working well. But it was probably something to do with soldering the leds. But who cares , main thing is that is working well . Thanks for all your replys regards<br />Me@n |
12-18-2001, 23:48 | #8 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | I will give you the right method to make leds without any problem: 01- Desold old leds<br />02- Clean the board ( led place )<br />03- put the new led on a plane surface and press it with a small screw driver to make it's motion impossible.<br />04- Solder the new led's pin out<br />05- Take the led with a screw-driver with a little sick, so you can move your hand easely.<br />06- Put the led on it's place<br />07- You can now solder it easly, but be carefull to not touch other's pin out.<br />08- After mounting all leds put the main board on the phone and test the leds with out the screen.<br />09- If ok you can mount all the phone now and you will have a nice bleu view... <br />10- If ther's a problem, plz resold leds without forgetting to test leds before mounting. Thanks for all, from a new member |
3310 problem after MADOS Flash File | Foz | Nokia Multimedia | 5 | 08-29-2007 22:52 |
SE or Interceptor Problem after Installation ... | Myco1GSM | Cruiser Suite | 2 | 12-10-2004 04:12 |
3310 problem after MADOS Flash File | Foz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-20-2004 00:16 |
Signal Problem after fitting white LEDs | karl123 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-19-2002 07:14 |
