06-09-2002, 14:49 | #1 (permalink) |
Junior Member Join Date: Jun 2002 Location: Philippines
Member: 12531 Status: Offline Thanks Meter: 0 | 3310 re-connect charger |
06-22-2002, 13:36 | #7 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Baroda Age: 42
Member: 5871 Status: Offline Thanks Meter: 87 | I got the same fault .. When we connect charger it charge then after when we pull up the charger it gets automatically charging & give message after half a minute RECONECT CHARGER & at that time it going to charge without charger ... then after it give message NOT CHARGING .. I had change all capacitor related to charging , I had change charging ic , & reflow the ccont also ... but problem is still contenue.. can any body help |
06-22-2002, 14:13 | #8 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
well-- it does not work-- teseted by me-- its ur luck if it works replacing charging ic -- does help in 50 % cases but no9t every time-- some body with 100% accurate solution ?? best regards gohar | |
06-22-2002, 14:26 | #9 (permalink) |
Member: 5871 Status: Offline Thanks Meter: 87 | I had not change one charging ic into that mobile I had remove charging ic from one okay 3310 then try it on that mobile but it is not working I had remove & i had seen that it was seem ok.. Again i had place that ic into okay 3310 & Ic was okay but i am facing same problem ... Help me .....!!!!! |
E250 when connect Charger, Charger goes Off | Adil Mobiles | Samsung Hardware Repair | 4 | 02-06-2010 12:06 |
Finel solution for Bad Connect charger , OR Invalid charger.... by Guljee | guljee786 | Chinese Models & Cloned Phones | 0 | 11-11-2009 08:55 |
Finel solution for Bad Connect charger , OR Invalid charger.... by Guljee | guljee786 | LG Hardware Repair | 0 | 11-11-2009 08:52 |
3310 not charging without connect charger | uwenk98 | Nokia Hardware & Hardware Repair | 3 | 03-07-2004 22:21 |
