Old 11-17-2002, 12:13   #1 (permalink)
Member: 12417
Angry 3310 restarts itself
3310 works perfect but some times restarts itself.
anybody help!!
Old 11-17-2002, 13:28   #2 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
change CCONT or rehoted with flux
Old 11-17-2002, 13:57   #3 (permalink)
GALAXY*gsm's Avatar
Member: 16449
Thanks Meter: 39
sorry dear how can u get this hardware wrong..... may be this is the last answer....
at first reprograming phone..(full flash ) .. if u donna have the tools (programes to make it contact me plz)...
then if the probleme not fixed check hardware.. try to clean the board by alcon then some thing of heat by hot air above ccont.. u will have a good result.....
best regards
galaxy
Old 11-17-2002, 14:33   #4 (permalink)
legija
Guest
Posts: n/a
Member:
Remove L511.
Old 11-17-2002, 15:48   #5 (permalink)
Member: 1060
Thanks Meter: 10
mix00
CCONT could be a problem if 32.768 clock is bad !
COBBA might hung phone , and it reset by MAD watch dog !
flash rom could be a reason,,,,,
you have to measure it before you make replace parts !
Willy
Old 11-18-2002, 10:29   #6 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
if this is not software than scrape your 3310
as willy said resetting can be due to
CCOUNT
cobba
32.768
flashrom
u have to change and chack
some phones dont reset when batt is full
but after few calls . Phone starts resetting....
i tried ccount in that but problem remained same
Old 11-20-2002, 04:15   #7 (permalink)
atlasgsm's Avatar
Member: 6420
Thanks Meter: 8
its a soft problem in 70% of cases
may be it help you
best regards...
Old 11-20-2002, 06:22   #8 (permalink)
Member: 16982
to willy
Hi willy your the best but i need more time read all your thread, can i ask you some thing about 3310 because i have 4 pcs 3310 with no network and i already change some parts but still no network, can you give description of step by step to fix this problem first what and second what??
thank you
regards
Irawan
3310 turning itself off sagir Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 12-12-2009 12:10
Nokia 3310 turnes itself off while talking ... discovery Nokia Hardware & Hardware Repair 7 04-07-2006 14:35
8310 restarts itself mix00 Nokia Hardware & Hardware Repair 8 09-22-2002 17:51
3310 switches itself off intermitantly bayleaf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-27-2002 21:51
3310 powers itself off or hangs? Read this! Safrane Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-06-2001 11:38
Page generated in 0.20319 seconds with 10 queries
