09-04-2002, 09:03 | #2 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | Hi iqballk If the phone is restart by itself then it's need full flash (include eeprom ), if not sucsses , go next step 1) 1)Chang your antenna not help, next step 2) 2)Chang PF109B (PA), If this not help, next step 3) 3)Rehot cobba with flux or replace it if nessesry. if not help go step 4) 4)Rehot ccont with flux or replace it if nessesry,if not help go step 5) 5)Rehot hagar with flux or replace it if nessesry goodluck Wesam Last edited by willy; 09-04-2002 at 16:12. |
The Following User Says Thank You to EGYGSM-TEAM For This Useful Post: |
09-04-2002, 16:16 | #3 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310- Signal Dropping.... Iqballk, I think , your COBBA has problem for cold solder ,it might can not read correct MSID , also flash rom have probrem too so it make contact service ! Willy Quote:
The Following User Says Thank You to willy For This Useful Post: |
09-09-2002, 14:47 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | cobba 100 c% cuz it happen after u work with msid data .. and use knock -phonix or rolis 1.71 i think its better than eeprom 3.10 and eeprom 3..1 is the best for 6110 and 5110 the models up better to use wht i sadi |
09-10-2002, 11:47 | #6 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Hi iqballk, do not you feel, when you state your question , it is too much SIMPLE ? Since mates tried to give you good hand, and your way to response still SIMPLE ! let we answer SIMPLE too with a JOKE ==> :P OK, "REPLACE A NEW PHONE" , MUCH SIMPLY and easy for you Willy Quote:
3310 signal drop... | mikko0707 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-04-2005 11:23 |
3310 Signal drops after few seconde from powering ???!! | crown | Nokia Hardware & Hardware Repair | 14 | 01-08-2005 20:20 |
3310 Signal drops... | BisoOY | Nokia Hardware & Hardware Repair | 10 | 08-08-2003 20:37 |
3310 signal drops every 30 sec, | carefone | Nokia Hardware & Hardware Repair | 10 | 08-04-2003 11:53 |
3310 signals drops and comes back | bre786 | Nokia Hardware & Hardware Repair | 11 | 09-08-2002 16:38 |
