Old 11-05-2004, 00:12   #1 (permalink)
crown's Avatar
Member: 29104
3310 Signal drops after few seconde from powering ???!!
hi
any solution for these big problem ,when switch on signal is good but after few second it drop down, i changed many components ,PA,Antenna switch,...etc .
but no result ,any solution guys ???
Old 11-05-2004, 06:09   #2 (permalink)
Member: 44625
Thanks Meter: 36
Could be COBBA problem. try reflowing or changing.
Old 11-05-2004, 07:50   #3 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
check VBATT to PA, look at circuite book if VBATT to PA cut then make a jamper, problem slove, if circuite good change CCONT. nertwork will be back
Old 11-05-2004, 18:51   #4 (permalink)
Member: 66225
Thanks Meter: 9
this problem PA chang it problem is solve
Old 11-06-2004, 16:30   #5 (permalink)
sumeda's Avatar
Member: 71960
Thanks Meter: 5
most probably trouble in cobba ic try to reflow or change it.
Old 11-06-2004, 17:07   #6 (permalink)
djyash's Avatar
Member: 15162
Thanks Meter: 61
i have repair a lot it is 100% pa .sometimes new pa faulty .
Old 11-06-2004, 17:43   #7 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
do jump for antina switch it will be solve
or do serch for this problem in this forum u will found u r problems slotion
*********************M.Azam*********************
Old 11-07-2004, 12:58   #8 (permalink)
mas comm's Avatar
Member: 75644
Thanks Meter: 5
Talking tested change pa
try to change pa, i ve checked it works ok.
Old 11-07-2004, 13:12   #9 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
First again flash phone (MCU+PPM) and then with "FAID" and "repair IMEI" and possible "unlock with eproms 3.1" ...if still same problem again change PA!
Old 11-07-2004, 18:09   #10 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
changing PA , can cause phone not to power on again.
please, try a new battery on your phone .
post your result .............
bestman.
if nor properly applied, this can cause no power on problem.
bestman.
Old 11-07-2004, 18:17   #11 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
Try to change antenna switch or jumper it and change PA and check Vbatt to PA if still problem
change Cobba
and good luck
Old 11-07-2004, 18:21   #12 (permalink)
goanga's Avatar
Member: 57035
Thanks Meter: 70
if pa is OK , antena switch is OK , vbatt to PA is OK ? THEN try to reflow with FLUX / change cobba / reflow change CCONT .... try relfow the FLASH ic !!!
Old 11-16-2004, 15:02   #13 (permalink)
ray_5572's Avatar
Member: 85689
Thanks Meter: 5
pa problem try change it
Old 11-23-2004, 13:09   #14 (permalink)
Member: 46218
can any one send me this software by mail,the ftp isn't work in my countrie
[email protected]
Old 01-08-2005, 20:20   #15 (permalink)
Member: 81153
Vbatt to PA
Friends,
I have seen people saying, check VBATT to PA.
What I want to know is.......should there be continuity? or should there actually be 3.6 volts on pins of PA?
I have measured in 3 or 4 phones today, and all of them had continuity, but none of them had voltage of 3.6....any suggestions?
Regards,
Raja3333
Nokia 6030 Signal drop and power off after few second Munir Memon Universalbox 3 07-21-2008 11:42
PLEASE ,please, drop signal after few second 1n 3310 , 6310 i change PA , HAGAR eng.hamdow Nokia Hardware & Hardware Repair 3 10-31-2005 09:00
8330 signal drop after few secs ... ?? TRABEL LG 4 08-16-2005 23:31
6230 signal drops after a few seconds jabran200 Nokia Hardware & Hardware Repair 12 12-25-2004 13:21
3310 hangs up after few seconds Dream gsm Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-14-2003 14:06
Page generated in 0.17862 seconds with 9 queries
