Old 11-10-2003, 11:19   #1 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
3310 signal ok only ~1-2h ?!?
what could be the problem with this phone ??
it came to me and didn`t had signal at all, so i resoldered all bga and had signal .. but after approx. 1 hour the signal was gone ..
i changed PA but problem remaines ..
i resoldered again and the signal came back .. but after ~1-2h was gone ..
very weird ...
thanx in advance ..
regards !
Old 11-10-2003, 15:42   #2 (permalink)
Member: 17711
Thanks Meter: 1,858
Try to locate some BGA that becomes very hot after this period of time...... I think it must be changed.
Old 11-10-2003, 20:05   #3 (permalink)
Member: 13545
Thanks Meter: 2
Your problem must be VCO or 26 mhz crystal...
Good Luck
MrHazeem
Old 11-11-2003, 10:44   #4 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
i removed ccont because it was heating .... but the network problem remained . . . thanx !
Old 11-11-2003, 11:16   #5 (permalink)
Registered User
Member: 20027
Thanks Meter: 5
Change 32KHz crystal. 100%......
Old 11-11-2003, 20:22   #6 (permalink)
Member: 41397
Thanks Meter: 2
hi where this 32 khz is located
Old 11-12-2003, 01:42   #7 (permalink)
Member: 19076
@sanjeev in,
The 32 khz crystal is B200 between the Ccont and COBBA IC, it is long in shape and most come in black color.
To check if it the source of the problem, yr phone must show hv the ff abnormality:
1. Slow Ring Tone.
2. Intermittent No Signal.
Any of the above is a sure sign that you hv a defective 32 khz clock crystal.
Best Regards,
loloph
Old 11-13-2003, 10:04   #8 (permalink)
celtec's Avatar
Member: 25504
Try to warm COBBA. If after warmed signal is OK, faulty is inside COBBA. Change it !!!
Alex
Old 11-13-2003, 10:07   #9 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
10x
i will and post result...
821SC unlocked w/ SIGNAL ok..... tested [Report OK] rea1One Z3X-Team Products 7 12-17-2009 15:36
Help!!! Nokia N70 with BL-6 Batere Signal OK & used BL-5 No Signal abellcell Nokia Base Band 5 ( BB-5 ) 0 12-05-2009 09:49
730SCII1 unlock done....Signal ok [Report OK] rea1One Z3X-Team Products 1 11-14-2009 04:19
3310 flash ok, ui setting default ok but phone is stii dead tarikalikhan Nokia Hardware & Hardware Repair 8 11-13-2007 05:47
3310 signal problem misel Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-07-2001 17:57
Page generated in 0.20359 seconds with 9 queries
