08-27-2002, 00:20 | #1 (permalink) |
Major Poster Join Date: Jul 2002
Member: 13660 Status: Offline Thanks Meter: 0 | 3310 signal and PA problem Is there any solution how to change the PA from black to silver without this problem or maybe it is not the PA problem. |
08-27-2002, 07:39 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Sometimes changing from Philips p.a(black) to Hitachi p.a(silver) will work if you align p.a correctly.You probably have a short circuit on one of the legs.Try another p.a and clean excess solder off before replacing. |
08-27-2002, 08:01 | #4 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310 signal and PA problem Patrynio, Let we say, your installed PA is good one ! when you swap two different PA ( black and silver) Philips and Hitachi ,, did you also try to install/remove R311 ? and have it flash phone ? with philips PA, you need 1K ohm at R311 ! with Hitachi PA, you need to remove it ! Willy Quote:
08-29-2002, 09:38 | #5 (permalink) |
Member: 13660 Status: Offline Thanks Meter: 0 | Well, I removed this resistor but it did not help. But I found where the problem was - hagar was not correctly soldered, I changed it and now phone works perfectly. Thanks to all of you. |
E530 poor signal and network problems | tcp30 | Samsung Hardware Repair | 4 | 06-17-2009 20:20 |
Nokia 1200 Signals and Charging Problem | Adil Mobiles | Nokia Hardware & Hardware Repair | 7 | 03-08-2009 22:52 |
SF65 No Signal and Camera Problems after flash | unlocker2000 | Multi-Box | 10 | 05-14-2006 13:47 |
3310 hang and restart problem | NITINWADHWA_NIT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 10-08-2005 16:11 |
3310 signal low after change PA and Antenna switch | Black-Axe | Nokia Hardware & Hardware Repair | 5 | 10-15-2002 14:35 |
