09-01-2002, 04:33 | #1 (permalink) |
Freak Poster Join Date: Sep 2001
Member: 6200 Status: Offline Sonork: 100.33330 Thanks Meter: 66 | 3310 signals drops and comes back Thanks in advance bre786 |
09-01-2002, 07:51 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310 signals drops and comes back Bre786 try to check 26M TXCO pin of AFC or replace it ! Willy Quote:
09-05-2002, 15:40 | #8 (permalink) |
Major Poster Join Date: Aug 2002 Location: sg Age: 49
Member: 14307 Status: Offline Thanks Meter: 3 | Believe me,, doing all of the trying is no use.... this is all happen with some of the 3310 board some of them, the board is the problem of else the ccont and hagar is the one how have bad solder underneath..... don do other thing,,,,, will not help...only thing u must do.... take out ccont and hagar if u like cobba as well...redo solder ball , make sure all of the ball make good and replace good(if u say don know how to make good later weill talk about it) make sure ( use good flux) check every of the cap and resistor around there is no lost and re**** with rework station...........Put back everything and try and see. if still not ok..... check every of the vtx vrx vsyn1,2 vref and etc..... if u realy want all of this long long time of work(: otherwise, there left one think all of the pple I know they will do is put a layer of thick tape upper ccont and put back all the thing screw and will press the ccont down to the pin and normally this tricks work all the time ....because this should be the board problem ,,,, this type of board will not stand longger heat time compare othere and will cause dammage underneath the bga pin thats why ...... hope this will help ....good luck!! |
09-05-2002, 18:33 | #9 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | HI Mikimiao, Thanks for your experience ... but,,, here,, i have some thing to state too ! i agree with you, if Hager does not have correct PLL loop, and CCONT does not supply working voltage , also PCB line cut or lost connect . how about, COBBA, MCU, TCXO .VCO ?? COBBA handle TXC ( tx power level control) , and RX IP/QP , AFC MCU ,, DSP , TXP, Hager control ....... TCXO for basic MCU running clock .max +- 200hz VCO, RF/4 oscillogram for TX /RX how about no TX by dead PA, also antenna switch ????? do repair phone,, first,, we have to fine out "WHY" phone does not work,, where got wrong ! Thanks Willy Quote:
09-06-2002, 14:21 | #10 (permalink) |
Member: 14307 Status: Offline Thanks Meter: 3 | Helo! willy.. I m fully agree with u. but no offence,,, this is not solving anything infact this add a lot of ?????? to this friend of us "bre786",,,, u r already talking engineer and design here ...........hope lucks go to every one!! |
09-06-2002, 18:36 | #11 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | HI Mikimiao, like Phone has no TX , then, of casue, we need to know "WHY" its not engineering only, it is proper way to solve problem... you cannot treat cancer by just removing cancer.. you need to kill cancer : ) to test using equipment and find out where and reason why phone got not worked not only try "LUCKY " PS, special thanks for mate Lampin ! Willy Quote:
3310 signal drop... | mikko0707 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-04-2005 11:23 |
3310 Signal drops after few seconde from powering ???!! | crown | Nokia Hardware & Hardware Repair | 14 | 01-08-2005 20:20 |
3310 Signal drops... | BisoOY | Nokia Hardware & Hardware Repair | 10 | 08-08-2003 20:37 |
3310 signal drops every 30 sec, | carefone | Nokia Hardware & Hardware Repair | 10 | 08-04-2003 11:53 |
3310- Signal Dropping.... | iqballk | Nokia Hardware & Hardware Repair | 6 | 09-11-2002 04:15 |
