Old 04-29-2002, 20:27   #1 (permalink)
Member: 5376
3310 still charging when unplug charger
Hi
my nokia 3310 still charging when unplug charger
i cleaned PCB, i changed connector....
Please help, any solution
regards
Old 05-15-2002, 01:35   #2 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Try a reflow of your CHAPS or Charging IC.
Old 05-15-2002, 01:47   #3 (permalink)
Member: 5376
Hi
Yhanks to replay
Is done but its the same
regards
Old 05-15-2002, 09:56   #4 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Reflow also your CCONT. Make sure you use good flux friend. If still the same replace both. Better also give me history of your phone. Dropped or water damaged... etc
Old 05-28-2002, 08:52   #5 (permalink)
Member: 5376
Hi
please help
regards
Old 05-28-2002, 08:56   #6 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
i replaced the ccont and ic charger but the pb still
continuis charge when unplug the charger.
Old 06-02-2002, 09:28   #7 (permalink)
Member: 5376
Hi
Please help
my 3310 still charging when unplug charger
regards
Old 06-03-2002, 05:06   #8 (permalink)
Own
Member: 5569
Thanks Meter: 10
Talking change only!!!
Please change only with ic charge control
Old 06-03-2002, 19:09   #9 (permalink)
Member: 5376
Hi
i change it the pb still the same
regards
Old 06-03-2002, 22:08   #10 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
hi
anyone know this pb
when i unplug charger i see this message display " reconnect charger.."
any helps plz
Old 06-04-2002, 01:57   #11 (permalink)
Own
Member: 5569
Thanks Meter: 10
Talking why not
i know you unplug and after unplug from phone ,phone show reconnect [battery signal run non stop and phone show charging all time after unplug RIGHT?]
Why are you not try change ic 4370621 [n100 = charging control ic]? change only [not rehot ]
Old 06-04-2002, 02:25   #12 (permalink)
Mod
Member: 3358
This workt for me on several phones.
Suggested by
Quang Thao
try wire from R200 pin
near CHAPS to R204 pin near CHAPS.
Regards
Mod
Old 06-04-2002, 21:44   #13 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
hi
sorry but not work for me
Old 06-04-2002, 23:07   #14 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
I guess some of the part is missing (while you reflow), so perhaps take a good pcb and check with your (reconnect charger pcb) and see the difference, what is the thing missing.
I do have this kind of prob and some times i solved this thru changing the Yellow Capacitor in the center part where the MAD located on bottom of the capacitor.(but this is not 100% working)
So Good Luck
3310 auto charging and then not charging and then reconnect charger hooi76 Nokia Hardware & Hardware Repair 6 08-17-2010 12:25
n3230 reboots when unplugged with charger west_bound Nokia Hardware & Hardware Repair 1 11-23-2006 18:20
3310 not charging without connect charger uwenk98 Nokia Hardware & Hardware Repair 3 03-07-2004 22:21
3310 still charging raivenz Nokia Hardware & Hardware Repair 8 09-15-2002 02:57
8210 still charging when unplug charger Rex Nokia Hardware & Hardware Repair 1 06-06-2002 09:26
Page generated in 0.28760 seconds with 10 queries
