01-14-2005, 20:01 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 44
Member: 68534 Status: Offline Thanks Meter: 18 | 3310 switching 4 lights only tawanda |
01-14-2005, 22:01 | #3 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | Quote:
i suggest you get 3310 Repair Guide 2004 by our brother Ben Ahmed (yassinov) the led is a minor work so use pcd diagram! | |
01-15-2005, 07:07 | #5 (permalink) |
No Life Poster Join Date: Dec 2003 Location: in the center of the heart
Member: 46125 Status: Offline Thanks Meter: 59 | hi lights in 3310 problem is a trck open open prob.check the continuity between the glowing and non glowing lights...and still if that doesnot work then its a prob of keypad interface IC which is located near the buzzer connection. |
01-15-2005, 09:42 | #6 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | hi tawanda "IF" i understand u corectly ur BOTTOM 4 leds turn ON only, and other 4 top dont "IF" this case then simply bridge wire from bottom working leds + n ground keep well |
01-17-2005, 02:40 | #8 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ROMANIA Age: 46
Member: 55427 Status: Offline Thanks Meter: 7 | As @magixian sed before all u need is schematic (check atachement). There are 2 possibilities: 1. led driver dead 2. intrerupted tracks How u resolve this is simple use a ohmmeter and see if u have continuity. leds have following configuration: one pin connected to +batt (positive connector of battery) and other to led driver (4370433). Now pay attention: All leds have one pin connected to +batt, but display leds are connected to pin 9 and keyboard to pin 13. If after this check u don`t find intrerupted tracks means u have dead driver and needs to be changed. good luck and BR, xyz |
01-19-2005, 19:22 | #9 (permalink) |
Product Supporter Join Date: Sep 2004 Location: PHILIPPINES Age: 46
Member: 81952 Status: Offline Sonork: 1597268 Thanks Meter: 2,364 | try to chech the line for its continuity using schematic diagram. if line is all ok and the resistance and still the 4 bulb not lighting then you need to reheat/reflow the CCONT, usually it happens when water damaged. try this, this is just an experience. ok |
n81 8gb light only light | shami61 | Nokia Hardware & Hardware Repair | 1 | 05-28-2008 22:59 |
3310 switch on only when charger connected | kprajeesh4u | Nokia Hardware & Hardware Repair | 1 | 05-28-2007 09:55 |
3310 after switching off, will only switch back on if you remove and replace battery | bilbo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-2003 00:41 |
3310 full 4 few sec. only | CellM@n | Nokia Hardware & Hardware Repair | 1 | 12-17-2001 20:57 |
