01-13-2006, 12:23 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 42
Member: 112071 Status: Offline Thanks Meter: 5 | 3310 vibrates when battery is inserted |
01-13-2006, 13:48 | #3 (permalink) |
Junior Member Join Date: Nov 2005
Member: 202155 Status: Offline Thanks Meter: 0 | some solution In most cases it is because of bad contact or water on main board, you need to heat main board,the best is to heat all, but must be careful with elements which are liquified with rubber ( chips which have around them rubber, rubber could be black,orange, white, usually if the chips have rubber, you just cover those which have rubber around, with metal case ( i usssualy use case which is used on board to cover elements) to protect them when heating around them, or you can just see with instrument buzzer where do the contacts of vibration go, and then just heat those elements which you trace with instrument. |
01-13-2006, 19:05 | #5 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | In case the phone is working propperly ( boot's Up and make calls ) , all you need is to change the N400 ( Lights/Ring/and vibration controller ) . but if the phone doesnt work at all ( dead ) and responce is that , change CCont . |
01-14-2006, 09:28 | #6 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Turkey/Kastamonu Age: 52
Member: 133173 Status: Offline Thanks Meter: 119 | Quote:
Nokia 6230: Noise when battery is inserted | smartmod.de | Nokia Hardware & Hardware Repair | 5 | 06-04-2007 16:54 |
6230 lights up when battery is inserted? | jtg | Nokia Hardware & Hardware Repair | 7 | 08-26-2006 16:00 |
6101 vibrates when battery is inserted | babyelephantt | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 05-21-2006 12:43 |
8910i test mode when battery is inserted | xDAN | Nokia Hardware & Hardware Repair | 0 | 03-18-2005 16:23 |
t20 gets hot when battery is inserted | bruce77 | Old Ericsson Phones & Sony Phones | 4 | 12-11-2004 15:13 |
