3310s can flash but dont power up i have a set of 3310s, i can flash them but dont power up help |
Hi, Just change the MAD ic |
wrong section!!! |
moved from Hardware Repair |
Change flash ic. |
the solution about that is chance flash ic1! |
1: flash IC 2: MAD 3: BSI to GND resistor Willy |
BSI to GND resistor ??? |
can you explain more BSI to GND resistor ! (location in schematic of service manual ??) |
i have same problem...can flash but no power on...what are numbers for: flash ic BSI2GND resistors? thnx |
check CCONT in some case do that good luck |
In some cases... if the phone doesn't power on even after successful flashing, try to identify the flash id first. If the flash id is not 00200090 then use 3330 fubu or flash the phone with 3310's fubu twice from 00200000 and 00400000.... |
@douda post the result ...!!! |
Please give us the link with schemes.I don't know what MAD,BSI and GSN resistors are. |
Hiya If You can flash but unit won't power up check ccont, B200 32768kHz osc, power consumption... Check old posts BR Vule |
