Old 03-13-2003, 23:48   #1 (permalink)
Member: 8903
3310s can flash but dont power up
i have a set of 3310s, i can flash them but dont power up
help
Old 03-14-2003, 13:29   #2 (permalink)
Member: 10125
Thanks Meter: 285
Hi, Just change the MAD ic
Old 03-14-2003, 19:37   #3 (permalink)
Member deceased !!
Winner58's Avatar
Member: 5
Thanks Meter: 1,883
wrong section!!!
__________________
read the Rules carefully!!!
wbr
Winner 58
Old 03-14-2003, 19:38   #4 (permalink)
Member deceased !!
Winner58's Avatar
Member: 5
Thanks Meter: 1,883
moved from Hardware Repair
__________________
wbr
Winner 58
Old 03-15-2003, 02:29   #5 (permalink)
Member: 11208
Thanks Meter: 11
Change flash ic.
Old 03-15-2003, 07:56   #6 (permalink)
Member: 23817
the solution about that is chance flash ic1!
Old 03-16-2003, 20:45   #7 (permalink)
Member: 1060
Thanks Meter: 9
1: flash IC
2: MAD
3: BSI to GND resistor
Willy
Old 03-17-2003, 23:39   #8 (permalink)
Member: 8903
BSI to GND resistor ???
Old 03-17-2003, 23:40   #9 (permalink)
Member: 8903
can you explain more BSI to GND resistor ! (location in schematic of service manual ??)
Old 03-29-2003, 21:59   #10 (permalink)
Member: 23790
i have same problem...can flash but no power on...what are numbers for:
flash ic
BSI2GND resistors?
thnx
Old 03-31-2003, 06:02   #11 (permalink)
amir-cairo's Avatar
Member: 11466
check CCONT in some case do that
good luck
Old 03-31-2003, 06:16   #12 (permalink)
Member: 3900
Thanks Meter: 31
In some cases... if the phone doesn't power on even after successful flashing, try to identify the flash id first. If the flash id is not 00200090 then use 3330 fubu or flash the phone with 3310's fubu twice from 00200000 and 00400000....
Old 04-10-2003, 06:14   #13 (permalink)
Member: 13545
Thanks Meter: 2
@douda
post the result ...!!!
Old 04-14-2003, 23:05   #14 (permalink)
mobileland's Avatar
Member: 22955
Sonork: 67574 - Not use it
Thanks Meter: 583
Please give us the link with schemes.I don't know what MAD,BSI and GSN resistors are.
Old 04-15-2003, 12:51   #15 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Hiya
If You can flash but unit won't power up check ccont, B200 32768kHz osc, power consumption...
Check old posts
Vule
3310 can flash but cannot power on mt-boy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-11-2007 06:31
3310 can flash but cant on GOODNESS Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-06-2005 01:25
3310 can flash but not power on?! sergo_zmeia Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-27-2004 22:46
3310 & 8210 can falsh but dont power up!! douda Nokia Hardware & Hardware Repair 1 02-02-2003 17:04
3210 can flash but no power on trafix Nokia Hardware & Hardware Repair 0 01-23-2003 19:16
Page generated in 0.47327 seconds with 8 queries
