Old 06-25-2004, 17:00   #1 (permalink)
.:::Dr. Cell:::.'s Avatar
Member: 48857
Thanks Meter: 31
Exclamation 3315 Signal drop
undefined Hi everybody. I ve encountered a problem with 3315 which was water damage. it got on by replacing ccont and heating the flash ic. and now the fault is dropping signals. i ve checked all the posts about this fault but nothing worked. i ve changed COBBA,Hagar, Vco,pa, antena switch but still same. signals come at once when i power on the phone and goes back before the lights turns off. But when i remove the clock cell(that black one) the signals starts coming and going but not stable. Plz suggest some solution. i ve also flashed the phone but the problem didnt solved.
Thanx in advance
Old 06-25-2004, 20:00   #2 (permalink)
Member: 44625
Thanks Meter: 36
Perhaps it is 26Mhz crystal. Are u sure PA is good?
Old 06-26-2004, 00:28   #3 (permalink)
Member: 12207
Thanks Meter: 2
As for me, you need to CHANGE PA. NOT resolder it! You need to change! Works for me most times...
Regards
XARiUS
Old 06-26-2004, 01:05   #4 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
why do you dry with heat?
why do you flash your phone ? when your phone is not funtioning properly?
step 1:
i do not know your heat level to your phone board?
try check your battery level.
check your antenna switch on your phone.
problem: you have flash your phone into network problem.
i have a suggestion for you.but,i need my answers for me to solve this problem.
*****************bestman****************
Old 06-26-2004, 11:54   #5 (permalink)
Member: 48857
Thanks Meter: 31
why i dried it with heat? well i usually do so and the mobile starts working perfectly actully i do it for drying the contact cleaner which is used to destroy rust. And ur second question when noting was working i flashed it but same. Heat level waednimum. how to check battery level i also changed a lot of batteries. i ve changed the antena switch but same. now say what to do?
Old 06-26-2004, 11:56   #6 (permalink)
Member: 48857
Thanks Meter: 31
i replaced the PA with a well working pa from the other working board. and the pa i removed from that damaged board is working perfectly on other board
Old 06-26-2004, 11:59   #7 (permalink)
Member: 48857
Thanks Meter: 31
plz tell me what must be the heat level to dry phone i am using 850 A+
Old 06-26-2004, 12:30   #8 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
around 400°C for 1 minute Max
Old 06-27-2004, 13:09   #9 (permalink)
Member: 38647
maybe line vb to PA broken...
Old 06-28-2004, 08:31   #10 (permalink)
Member: 48857
Thanks Meter: 31
i ve already removed the jumper and connected with jumper. VB track is also good and giving connectivity.
Kia problem hay yaaaaaaaaaaaaaaaar?
Old 06-29-2004, 19:42   #11 (permalink)
Member: 44625
Thanks Meter: 36
Hey guys, please post in english so everyone can understand. Though i can follow u, others can't. What would happen if everyone posted in their own languages? There would be total chaos n nobody would be able to learn.
Old 06-30-2004, 09:07   #12 (permalink)
Member: 48857
Thanks Meter: 31
Oh so sorry. Well mr Azam i cant send u picture of the mobile coz it is the same board like 3310 and u know it very well i think, And one other thing plz tell me how is the charm of mobile repairing business here in KSA coz my father is too there and he want to settle me there with the same business here. Plz tell me . and also can u easily get mobile parts and repairing tools here and what is the cost to start a new business and also what average money u charge to a client? Thanxx
Old 06-30-2004, 11:29   #13 (permalink)
BoOzer665's Avatar
Member: 44186
Sonork: 100.108965
Thanks Meter: 65
chek the tones .. if thy r going slow just recheck the ccont.. i v passed by the same once..
Old 07-01-2004, 09:20   #14 (permalink)
Member: 48857
Thanks Meter: 31
ok i ll post results. And mr Azam i ve added u to my msn but please tell me when u sign in to msn
Old 07-01-2004, 17:35   #15 (permalink)
fone's Avatar
Member: 17367
Thanks Meter: 16
PA line batt cut ,u must connect line vbatt to PA
T10 no full network, signal dropping pali Sony Ericsson Hardware Repair 1 06-01-2002 17:26
8210 ,signal drops . ags28 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-15-2002 17:31
Signal Drop Solution for 6210 schwantz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 03-26-2002 22:46
Repair signal dropping after IMEI ch! gyuszko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-11-2002 15:35
3210 no signal dropped???? eureka8888 Nokia Hardware & Hardware Repair 3 08-25-2001 19:13
Page generated in 0.24024 seconds with 9 queries
